wat do i need for a lsv swap into a ef
Old Nov 27, 2007 | 09:34 AM
guttedefsi's Avatar
Default wat do i need for a lsv swap into a ef
and i would like to do ctr cams and pistons and mostly ctr will i be able to do that wen i get my block bored .20 over or i should i need help with this build
the build is goin to be all motor no boost
Old Nov 29, 2007 | 10:36 AM
NATEDEEZY's Avatar
FROM WHAT I KNOW I THINK YOUR GONNA NEED
AXLES AND HALF SHAFT
MOTOR MOUNTS
B SERIES CABLE TRANNY
SHORTEND SHIFT LINKAGE OR AFTERMARKET
ECU AND JUMPER HARNESS DEPENDING ON IF YOU GO OBD1
AND DPFI TO MPFI WIRING HARNESS IF YOU GOT A DX OR STD HATCH
AND IM NOT SURE WEATHER YOU HAVE TO CHANGE YOUR FRONT ROTORS OR NOT ??
Nateman2
Jul 18, 2016 01:47 PM
mightymikee
Apr 17, 2010 11:12 AM
whokid_911
Sep 18, 2009 10:14 AM
hasty91ef
14
Mar 14, 2009 08:32 PM
spens 91 Ef
Oct 26, 2008 05:26 PM
