car is missing ?'s fuel pressure or other problem
Old Nov 27, 2007 | 07:59 AM
darkd1gt's Avatar
Default car is missing ?'s fuel pressure or other problem
ok so i have a 95 si with a h22a in it. The car has run fine for 3 years all of the sudden it started missing. I have all ready changed out the plugs, distributor cap rotor button, fuel filter, and air filter.
fuel pressure was kind of high so i turned it down to around 35 vacuum on 42 vacuum off. It was around 40 to 48 before and has been running like that fine for around a year now.
It has the distributor and coil from the si. Thats how its been since i had the motor installed like 3 years ago. Im getting a new set of plug wires soon they are like 3 years old. any clue as to what the problem is before i spend any more money?
Old Nov 27, 2007 | 08:02 AM
Hawkze_2.3's Avatar
Default Re: car is missing ?'s fuel pressure or other problem (darkd1gt)
Like missing on one cylinder every now and then, or running rough all the time or what? More details!
Old Nov 27, 2007 | 08:06 AM
darkd1gt's Avatar
Default Re: car is missing ?'s fuel pressure or other problem (Hawkze_2.3)
it all the cylinders i think. it started a month ago started missing once in a while. while driving. Changed a few parts drove fine for a week. did it again. This time it missed so bad it was hardly going. Then few hours later magically cleared up and worked fine for another week. Now when idling it misses like every 10 seconds or so.
Old Nov 27, 2007 | 08:09 AM
Hawkze_2.3's Avatar
It sounds like an electrical issue, but I could be wrong. You might double check your plug wire connections to start with, then maybe check the ignitor and coil and their connections. Do you get any check engine lights?
Old Nov 27, 2007 | 08:10 AM
darkd1gt's Avatar
i changed the plugs 2 weeks ago and then again yesterday. yesterday they had carbon build up on them and a redish tint on the white part.
Old Nov 27, 2007 | 08:11 AM
darkd1gt's Avatar
no cel's, i checked the plug connections they are good, i know where the coil is but where is the igniter?
Old Nov 27, 2007 | 08:25 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkd1gt &raquo;</TD></TR><TR><TD CLASS="quote">no cel's, i checked the plug connections they are good, i know where the coil is but where is the igniter?</TD></TR></TABLE>
Inside the distributor, they commonly go out but usually the car won't run without it. It looks like a little black computer part...(also called ICM )
Old Nov 27, 2007 | 08:27 AM
mgags7's Avatar
Sounds a lot like a failing ICM to me, they can go out bit by bit.
Old Nov 27, 2007 | 08:53 AM
darkd1gt's Avatar
Default Re: (mgags7)
yeah i just went to walmart and got a multi meter thanks for the help so far
Old Nov 27, 2007 | 09:20 AM
darkd1gt's Avatar
Default Re: (darkd1gt)
yeah i went and checked it the black yellow and green wire had voltage. and the blue and yellow green didn't have any voltage and according to this online guide it says i need a new igniter. that sound about right ?
Old Nov 27, 2007 | 09:23 AM
Hawkze_2.3's Avatar
Yep, sounds like an ignitor/ICM would do it.
darkd1gt's Avatar
Default Re: (Hawkze_2.3)
cool thanks for the help guys ill let u know how it turns out
Old Nov 27, 2007 | 12:33 PM
darkd1gt's Avatar
well that didnt do the job....any other suggestions
Old Nov 27, 2007 | 01:31 PM
bluedlude's Avatar
well, is it all the cylinders misfiring or not? if its only one cylinder its probably a injector if you already replaced everything. if its all of them id check to see if your timing is still on from the cam gears.
Old Nov 27, 2007 | 01:49 PM
darkd1gt's Avatar
Default Re: (bluedlude)
yeah timing is still on. i assume its all the cylinders misfiring because all the plugs were fouled.
Old Nov 27, 2007 | 02:05 PM
bluedlude's Avatar
before i get into it, when you say your car is misfiring. because you feel it, or because you got a CEL and checked it?
Old Nov 27, 2007 | 02:22 PM
darkd1gt's Avatar
because i can hear it and it cut off on my girlfriend the other day in traffic. ive had cars misfire on me before and i know how it feels and sounds as well.
Old Nov 27, 2007 | 02:27 PM
bluedlude's Avatar
hmm, what RPM does it idle at?
Old Nov 27, 2007 | 02:29 PM
darkd1gt's Avatar
and why would the plugs be covered with carbon build up after 2 weeks.
darkd1gt's Avatar
car idles at 650 700 its easier to hear the misfire when it first cranks up when its fast ideling
Old Nov 27, 2007 | 02:39 PM
bluedlude's Avatar
i dont really understand how you hear a misfire. maybe feel it but not hear it. or maybe i just have bad ears. i dont know
Old Nov 27, 2007 | 02:59 PM
nemesis25's Avatar
Check your ECT sensor connection. My civic did this a while back but I did had a code 6.
Old Nov 27, 2007 | 04:03 PM
darkd1gt's Avatar
Default Re: (nemesis25)
found the problem plug wires. cleaned it right up.
Old Nov 27, 2007 | 04:06 PM
darkd1gt's Avatar
although i think the fuel and the igniter were off as well thanks for the input guys.
Old Nov 27, 2007 | 04:10 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">i dont really understand how you hear a misfire. maybe feel it but not hear it. or maybe i just have bad ears. i dont know </TD></TR></TABLE>
It will just sound like a blip in the hum of the engine.
GregoryBRCRV
Honda CR-V & Element
Feb 17, 2016 08:58 AM
Lude #1
11
Jan 9, 2011 01:05 PM
92integraVTECgsr
Oct 20, 2010 05:44 PM
dgreenwud
Nov 16, 2003 04:29 PM
