Need help with changing the accessory belts
Old Nov 26, 2007 | 08:08 PM
ricerodder91EX's Avatar
Default accessory belt access question?
basically what in the heck do I have to, should I have to, remove to get to the damn things?
I looked at the autozone website, couldn't find the steps. thanks in advance.
Modified by ricerodder91EX at 9:37 PM 11/26/2007
Old Nov 26, 2007 | 08:16 PM
VtecSyndrome's Avatar
Default Re: Need help with changing the accessory belts (ricerodder91EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricerodder91EX &raquo;</TD></TR><TR><TD CLASS="quote">basically what in the heck do I have to, should I have to, remove to get to the damn things?
I looked at the autozone website, couldn't find the steps. thanks in advance.</TD></TR></TABLE>
If you need directions on how to do this then you need to pay somebody else to do it for you, if you were the least bit mechanically inclined you could figure it out, it's about as easy as anything gets when it comes to working on cars. you are likely going to break some stuff before you get it right.....take it to a professional or at least a mildly skilled friend and save yourself the headache
Old Nov 26, 2007 | 08:28 PM
Default Re: Need help with changing the accessory belts (VtecSyndrome)
that is probably one of the funniest responses I've ever heard, perhaps I could have asked better questions. Do I have to jack the car up and remove the splash shields and get at it all from underneath. I wanted to avoid that if possible cause I (as in myself) installed in lowering springs and its very low and now a pain to get my jack under there. I have also replaced the steering knuckle and both axles. But for some reason I am put off by the accessory belts cause I'm so use to it being so much easier and simple on mopars.
Old Nov 26, 2007 | 08:37 PM
503_EF9's Avatar
its one of the simplesest things you can do.
both the ac and alternater have brackets with a 12 mill bolt that you loosen. move the bracket to slip the belts over the crankpulley and the alternater or ac and then push the accecery to tighten the belt while simotaneously tighting the 12 mill bolt to secure the belt in a tight manner.
you should be able to do all this from the top with very simple tools.
Old Nov 26, 2007 | 08:43 PM
Default Re: Need help with changing the accessory belts (503_EF9)
ok thanks.
Old Nov 26, 2007 | 09:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 503_EF9 &raquo;</TD></TR><TR><TD CLASS="quote">its one of the simplesest things you can do.
you should be able to do all this from the top with very simple tools.</TD></TR></TABLE>
Old Nov 26, 2007 | 09:08 PM
you guys must have tiny hands.
Old Nov 26, 2007 | 09:16 PM
boostedwagon's Avatar
MOPAR or <U>NO CAR!!</U>
Old Nov 26, 2007 | 09:21 PM
Hanmin's Avatar
Default Re: Need help with changing the accessory belts (boostedwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedwagon &raquo;</TD></TR><TR><TD CLASS="quote">MOPAR or <U>NO CAR!!</U> </TD></TR></TABLE>
get out, right... now...
Old Nov 27, 2007 | 04:52 AM
I drive hondas when I want to save gas and mopars when I want to go fast.
Old Nov 27, 2007 | 05:19 AM
~sp33~'s Avatar
EFB055
Did 'gas' and 'fast' rhyme when you said it? lol.
Old Nov 27, 2007 | 09:36 PM
Default Re: (~sp33~)
yes yes you say it like from the street "fas man, really fas"
SilverRed
Oct 27, 2007 09:21 AM
ONELIFEMOTORSPORTS
17
Oct 27, 2006 04:27 PM
89hbcivicguy
22
Mar 13, 2005 07:11 AM
civicguy1984
Nov 11, 2004 03:13 PM
civic702
Apr 6, 2004 04:49 PM
