obd0 intake manifold question
Old Nov 26, 2007 | 07:14 PM
thesoundofturbo's Avatar
Default obd0 intake manifold question
hey guys im running obd0 on my 88 hatch converted to mpfi.
i swapped in a y8 with a A6 dizzy to stay obd0.well the problem is i dont have a D16a6 Intake manifold to stay obd0 but i have the injectors for it.
but i do have a Z6 IM and wondered wats the differece between installing the Z6 one.
like where do i put the MAP sensor hoses at?
and can i use the Z6 throttle body? cause theres 2 sensor on it unlike the A6 throttle body only has one.
so i really need help from u guys thanks.
Old Nov 26, 2007 | 07:38 PM
alscrx's Avatar
Default Re: obd0 intake manifold question (thesoundofturbo)
Take some pics
Old Nov 27, 2007 | 06:53 AM
89efDUSTY's Avatar
You can run the z6 IM in its place, only main difference will be the map mounted on the TB. Because if you think about it you can leave you purge solenoid valve still attached "located near OBD0 map on the firewall", then just extend your wires from the previous map to reach the TB. Anything else on the z6 that is not on the a6 "if there is anything such as FITV on other IMs" should not need to be hooked up because its just like you are running the a6.
4,000th post!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 27, 2007 | 07:23 AM
Default Re: obd0 intake manifold question (89efDUSTY)
alright thanks man ill look into it today
puertoricanboy90
35
Dec 4, 2008 07:48 AM
rice a roni
11
Mar 12, 2007 12:32 PM
Screaming
14
Mar 30, 2006 03:56 PM
4DRmafia
19
Mar 4, 2006 06:11 PM
EJ2-Fluffy
Jan 15, 2005 01:51 PM
