Rattling noise, like loose tin plate sound when I rev high or press clutch (exhaust note set off)
Old Nov 26, 2007 | 06:57 PM
c 2's Avatar
c 2
Default Rattling noise, like loose tin plate sound when I rev high or press clutch (exhaust note set off)
Hey All!
I'm hearing a slight almost faint tin like rattling sound from my honda engine bay when I either rev my car (With performance exhaust) or when I'm driving at high revs and changing gear. The sound is set off by the slight vibrations the exhaust makes. After the exhaust note comes down so does the rattling. I started experiencing this sound after my cat back exhaust was installed in my DC5 but I checked all the bolts and nuts and they all seem to be done up tight. It's comming from the front of the car (under the hood). Would anyone have a clue on what it is or might be??? Thanks everyone. I appreciate it. All suggestions are welcome.
Old Nov 27, 2007 | 05:45 PM
risktypeS's Avatar
Default Re: Rattling noise, like loose tin plate sound when I rev high or press clutch (c 2)
check your heat sheild and see if it's loose.
Old Nov 27, 2007 | 06:18 PM
richie`s_dc5's Avatar
It might be the ivtec cover...it may be loose..take it off and then rev the car...I think the noise should go away....I had a similar issue...
Old Nov 27, 2007 | 07:02 PM
c 2's Avatar
c 2
Default Re: Rattling noise, like loose tin plate sound when I rev high or press clutch (richie`s_dc5)
thanks guys, il try that and il see if it goes away.
Thanks again
Old Nov 27, 2007 | 07:04 PM
risktypeS's Avatar
i had that same issue with the cover. i just took it off. That could be the rattle.
dc5RickK20's Avatar
i think its some kind of heat sheild thats loose i had the same prob but it was this weird sheild under the car that cnnects to the sub frame
Old Nov 27, 2007 | 07:11 PM
risktypeS's Avatar
Default Re: Rattling noise, like loose tin plate sound when I rev high or press clutch (dc5RickK20)
yeah the heat sheild above the cat.
Old Nov 28, 2007 | 01:31 PM
c 2's Avatar
c 2
Default Re: Rattling noise, like loose tin plate sound when I rev high or press clutch (risktypeS)
aah yes, I know the one, that could be it, maybe it was disturbed when they installed my catback system, or maybe its slightly loose due to the exhaust notes' vibrations.
Vague
Apr 26, 2015 01:05 PM
strictly.business
May 25, 2006 03:15 PM
valentinecr
Dec 27, 2004 05:58 PM
dkorea918
14
Oct 14, 2004 01:13 AM
awall
Apr 20, 2002 02:10 PM
