GSR Master Clutch cylinder into 93 cx
95 B18C swap in an EG
I need new master/slave clutch cylinders.
I dont have a clue if it already has the GSR master/slaves from when the swap was installed.
All I want to know is if I can buy GSR master/slave clutch cylinders to replace the blown out ones and that the master will be a direct bolt on into the EG shell.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onsetofpurity »</TD></TR><TR><TD CLASS="quote">95 B18C swap in an EG
Thanks
Yes it will fit. Its the exact same part as the stock master and slaves. I have interchanged both before with no problems many times.
Thanks
</TD></TR></TABLE>Yes it will fit. Its the exact same part as the stock master and slaves. I have interchanged both before with no problems many times.
motrayEG6
Mar 2, 2011 09:04 AM
DB1_559
Jun 1, 2006 07:22 AM
