toda springs with spec A's or not with stock (been seaching for days)
Old Nov 26, 2007 | 05:45 PM
ricekiller1's Avatar
Default toda springs with spec A's or not with stock (been seaching for days)
im wondering if its is worth swappin out the itr valvetrain for toda springs when putting in toda A's..do the A's make enough power up top to rev past the stock redline with a just a mugen HG to bump the compression on an otherwise stock ITR motor(IHE)????? thanks guys
Old Nov 26, 2007 | 06:44 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: toda springs with spec A's or not with stock (ricekiller1)
Any aftermarket cam will make power higher than the stock limit and so will the Toda A's. A simple Google search on Toda gave me the specs for those cams and they also specified that you must upgrade valvesprings to run their cams. All that info in only 3 mins...
Old Nov 26, 2007 | 06:53 PM
Default Re: toda springs with spec A's or not with stock (00Red_SiR)
thanks for the reply man...
Old Nov 27, 2007 | 03:24 PM
up
Old Nov 27, 2007 | 11:25 PM
mcclungd2000's Avatar
you might as well do it right the first time to avoid any issues later. I'd also look into the supertech valvtrain over the toda valvetrain if you want to save like $400.
ricekiller1
Dec 3, 2007 07:23 PM
ricekiller1
Nov 27, 2007 03:18 PM
JDM TypeR 307
Dec 29, 2003 02:13 AM
MugenB16A2
Dec 2, 2003 12:37 PM
Black R
Dec 27, 2001 12:43 PM
