NITROUS EXPRESS on sale brand NEW free shipping
hey, i just got a lot of nx stuff for pretty cheap, so i figure i will pass the savings to you. i can get a lot of each of these, so let me know. email me drdavidge@aol.com or reply here if interested. for sale:
ALL Import Stage One EFI Single Nozzle System (35-50-75 hp) $500
Utilizing the patented Shark nozzle these systems are fully adjustable 35-50-75 horsepower for 4 cylinder and V-6 applications. These systems require no engine modifications operate on stock fuel pumps and require no timing retards. The ultimate solution to make your import a Rocket. Any horsepower settings above the recommended levels require NX Power Booster fuel additive to prevent detonation.
EFI Hitman Single Nozzle System (50-75 hp) $425
This system is perfect if you just want a small nitrous system to give you the additional boost when needed. Includes:
5lb bottle
Pure-Flo Valve
Stainless Steel Bottle Brackets
Piranah Nozzle
50-75HP Jets
Aircraft Steel Braided Hose
Arming Switch
Push Button
..and al lthe necessary fittings.
These systems require no engine modifications operate on stock fuel pumps and require no timing retards. Any horsepower settings above the recommended levels require NX Power Booster fuel additive to prevent detonation.
Incognito Hidden Dry System $210
If you only need a little help then the Incognito system is your ticket. With no fuel enrichment capabilities the Incognito is designed to help burn that last bit of fuel in the combustion chamber. With auxiliary fuel enrichment the Incognito system can make up to 150 extra horsepower! System comes with 1.4Lb. Bottle - nitrous solenoid - fill fitting - -4 cap - 15 ft black poly line - and assortment of jets.
Gen X 2 Accessory Pack $335
Add this and any kit and you become a serious nitrous racer. This has everything you need to run quicker as well as be more consistent and safer. The kit contains:
a bottle heater to insure proper pressure and consistency
a bottle pressure gauge to monitor pressure
a fuel pressure safety switch and manifold to keep your engine from going lean and having a major problem
a safety blow down tube to vent excessive n2o pressure to the atmosphere
a purge valve to vent gases and insure the system receives a liquid shot of fresh nitrous.
Automatic Remote Bottle Valve Opener $200
Five years of research and development has finally produced the ultimate solution the Nitrous Express Next Generation remote bottle opener. The NX remote opener is guaranteed not to effect horsepower output or cause the surging sensation associated with current designs. It is furnished with all installation hardware and weather-pack wiring kit. (Fits any brand nitrous system)
5lb bottle
Pure-Flo Valve
Piranah Nozzle
50-75HP Jets
Arming Switch
Push Button
can we get a group buy on this to make the price come down some more? I'm interested in the 75 shot single fogger with the accessory kit.
actually, i think the guy i know has one going on on groupbuycenter.com right now. check it out, his company is after hourz racing.com
will the igcognito work on a honda? on some sites it says carburated, just not sure at all. and its listed on the nx site next to the plate systems. hmm.
jcstites@excite.com
jcstites@excite.com
yep, works on hondas. if you saw fast and furious, its kinda like the **** that vin diesel has in his RX-7 where he picks up the seat and its in there..its a little bottle like that but it works. my friend has it on his civic. its pretty cool.
The chrome pro fitting allows you to connect the bottle warmer transducer and the bottle pressure gauge to the backside of the bottle valve, instead of having to put it inline with the feed line.
I'm not sure if its released yet though. Its advertised on the nitrouswarehouse.com site and is included with the supposed genx3 kit.
wushubrian
Northeast (Sales)
Feb 16, 2007 02:58 PM
TranspeedMotorsports
Sep 16, 2006 12:52 AM
