5 1/4 or 6 1/2 for doors?
Old Nov 26, 2007 | 04:22 PM
D16Z6racing's Avatar
Default 5 1/4 or 6 1/2 for doors?
I'm looking at replacing my doors speakers this week. Anything beats the oem speakers.
What are guys using for door speakers? I'm working on my 90 Civic Sedan. It's listed as 6 1/2's, but every site also says 5 1/4's will fit. I'm at work other wise I'd go look right now.
I've already got a pair of 6 1/2's in my basket (shopping online as I type) for my rear deck speakers, just needed that extra assurance for the doors.
Thanks HT-ers.
Old Nov 26, 2007 | 04:28 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: 5 1/4 or 6 1/2 for doors? (D16Z6racing)
A standered 6.1/2 will fit your doors. You can also use a 5.1/4 speaker too. Use the 6.1/2 and your good to go.
Old Nov 26, 2007 | 04:31 PM
Default Re: 5 1/4 or 6 1/2 for doors? (wrx-killer-Sti-eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti-eater &raquo;</TD></TR><TR><TD CLASS="quote">A standered 6.1/2 will fit your doors. You can also use a 5.1/4 speaker too. Use the 6.1/2 and your good to go.</TD></TR></TABLE>
Thanks.
Buying 2 pairs of 6 1/2's now.
Old Nov 26, 2007 | 04:33 PM
Old Nov 26, 2007 | 07:49 PM
incubus's Avatar
becareful what you purchase. actual 6.5"s dont fit hondas. you need 6"s
if you want a good set of drop in speakers, boston acoustic makes a a Honda specific 6" they are a direct fit.
http://www.bostonacoustics.com...d=234
Link ^
Old Nov 27, 2007 | 04:43 AM
draperj09's Avatar
Default Re: 5 1/4 or 6 1/2 for doors? (incubus)
I've had in 5 1/4 xplods, 6 1/2 xplods, and 6 1/2 pioneers.
I've never had trouble fitting 6 1/2s.
Old Nov 27, 2007 | 07:23 AM
White Smoke's Avatar
i my honda
Global Mod
A MDF mounting ring will make a world of a difference as well!
Old Nov 27, 2007 | 08:45 AM
J's91Teg's Avatar
Default Re: 5 1/4 or 6 1/2 for doors? (White Smoke)
I always got away with air sawing the plastic basket a little to make em fit. Just make sure the depth don't come close to the window.
I like those Boston's... Have you hear a pair of them? What are they comparative too? Also, I was unsure when looking, but do they have Components to match well with those coaxial??
Old Nov 27, 2007 | 08:07 PM
fcm's Avatar
fcm
Old Fart
As mentioned, you can use 5.25" speakers. [although you may need a gasket to get a seal, depends on brand] or you can use a standard 6.5", [not to be confused with the over-sized 6.5"] your stock speaker is a standard 6.5" with a 2" mounting depth.
The main diff. between standard 6.5" and over-sized 6.5" speakers is the mounting hole diameter, the standard 6.5" uses a 5" diameter mounting hole, the over-sized 6.5" uses a bigger then 5" diameter mounting hole and the size depends on the brand and even the model of a brand.
EG; the Alpine SPR-17C... http://www.alpine-usa.com/US-e...R-17C is called a 6.5" coax, but it needs a 5-5/16" mounting hole...
The Alpine SPS-17C2... http://www.alpine-usa.com/US-e...-17C2 also called a 6.5" coax, but needs a 5-39/64" mounting hole....
The Alpine SPS-M600... http://www.alpine-usa.com/US-e...-M600 also called a 6.5" coax, but it is a standard 6.5" speakers and needs a 5" mounting hole.
The other issue is mounting depth, as mentioned, stock is 2" or less.
There are ways "around" all the above, also as mentioned MDF "rings", [adapters] will give you and extra 3/4" - 1" mounting depth, cutting a hole for the speaker magnet will get you another 1/2" - 3/4" of mounting depth.
The MDF adapter ring can also be used to install an over-sized 6.5" speaker into the standard 6.5" OEM speaker housing.
So the question is, what 6.5" speakers did you order????? 94
Old Nov 27, 2007 | 09:09 PM
Default Re: 5 1/4 or 6 1/2 for doors? (fcm)
^^^ amen
Old Nov 28, 2007 | 04:18 AM
SincereLEE's Avatar
i had pioneers 5 1/4 and jl audio 6 1/2
Old Nov 28, 2007 | 07:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">So the question is, what 6.5" speakers did you order????? 94</TD></TR></TABLE>
Kenwood KFC-1651S
They were $25 a pair new. Pretty much a upgraded oem style speaker.
This is just my 'park & ride' car. The factory speakers crackeled with the volume at 2. Just gets worse with any adjustments made.
I just got a new Kenwood KDC-135 deck for $70. I only need to get to 12 on volume, so no big bump needed.
Old Nov 28, 2007 | 11:22 AM
fcm's Avatar
fcm
Old Fart
They will fit without any mods, you will even find 3 holes that line up with stock mounting holes. 94
Derrick Berry
Mar 16, 2020 03:22 AM
420_EM1
Dec 20, 2013 11:07 AM
Crackerballer
Audio / Security / Video
Apr 7, 2013 11:29 AM
Unjockable
12
Dec 15, 2003 10:22 AM
Loveless
Feb 20, 2003 09:38 AM
