Oil in All Cylinders
Old Nov 26, 2007 | 01:26 PM
Global688's Avatar
Default Oil in All Cylinders
So I replaced my headgasket and I was rotating the motor to find TDC and well I am a dumbass and forgot to remove the sparkplugs and now I have oil in all the cylinders.
So H-T how bad did I expletive this up?
Any opinions what I did before I tear the head back off or am I just overeacting?
Old Nov 26, 2007 | 02:25 PM
averyvm's Avatar
Default Re: Oil in All Cylinders (Global688)
I dont understand how does turning the motor over suck oil down into the cylanders
Old Nov 26, 2007 | 09:47 PM
quik1's Avatar
Default Re: Oil in All Cylinders (averyvm)
How much went down. Crank the engine over with no plugs in you'll be fine.
Old Nov 26, 2007 | 10:11 PM
civicstar's Avatar
do as quik1 said get out as much as possible. when you put them back in and start it, it might smoke for a little bit, let it burn off and it will be fine
Old Nov 27, 2007 | 05:27 AM
Global688's Avatar
Default Re: Oil in All Cylinders (civicstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">How much went down. Crank the engine over with no plugs in you'll be fine.</TD></TR></TABLE>
yeah did just that and most of it went away
thanks guys
PaChiLa Leader
Apr 25, 2007 09:15 AM
EF8_03
Mar 12, 2007 02:51 PM
bulldog_RS20
Aug 18, 2004 11:35 PM
usdmcrx
Feb 24, 2004 06:46 PM
Al Czervik
Jun 10, 2003 01:29 PM
