Suspension & Brakes Theory, alignment, spring rates....
How much to preload?
Old Nov 26, 2007 | 01:16 PM
ZXVIIR's Avatar
Default How much to preload?
before setting up coilover (i have FF type 2's), how much should someone preload on springs before install?
i'm trying to see if this is the soloution for thisproblem?
https://honda-tech.com/zero...46579
note: springs do have some kind of load by hand, they arent loose or dangling when there is not load on assembly.
Old Nov 26, 2007 | 01:50 PM
TunerN00b's Avatar
Default Re: How much to preload? (ZXVIIR)
I've been daily driving my GSR for nearly 2 years on Ground Control sleeves, with none of the springs preloaded. The weight of the car is adequate to keep the springs seated, and even when I lift the inside rear cornering, the swaybar keeps the lifted tire's spring seated.
Only issue is lowering the car off a jack, and only once has a spring ever failed to seat correctly on its own. Even then, I just pushed the fender a little side to side and the spring seated itself.
I don't think preload is really a concern. Thats an opinion though.
edit* If you're jumping the car, adn can get an entire axle off the pavement, then I suppose you might have to start worrying about the spring unseating. However, I think under such circumstances, you have bigger concerns than your springs reseating correctly.
Old Nov 27, 2007 | 06:38 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The spring preload perches should be just snug under the spring to keep them in place when at full droop. No additional preload is necessary.
vinuneuro
Suspension & Brakes
Oct 17, 2007 11:25 AM
rambyCAMRY
Apr 6, 2004 10:51 PM
solo-x
Sep 5, 2002 05:36 PM
VTECAcuraGSR
17
Jun 21, 2002 10:47 PM
garados
Feb 5, 2002 02:41 PM
