Push Button Start
Old Nov 26, 2007 | 01:01 PM
jbarrett652's Avatar
Default Push Button Start
I was wondering if anyone out there has tried to install a push button start from the s2k in there cars? If so how easy is it? Any how-to's out there?
Old Nov 26, 2007 | 10:19 PM
civicstar's Avatar
Default Re: Push Button Start (jbarrett652)
it just depends how you are gonna wire it, once you find a place to put it, you can wire it to the starter signal right on your ignition wiring, its not that hard if you know what your doing and what wire it is. just take out the panels, and find the wire and then find a good place to mount it
Old Nov 27, 2007 | 06:06 AM
SuzukaBlueAP2's Avatar
Default Re: Push Button Start (civicstar)
Piece of cake. I installed one in an Integra a few years back. I put it where the cruise control switch was.
Once i got a diagram of the wires under the steering column, it took about 30 minutes to get it wired up and everything back together.
Just a note, when you are making these connections, use a soldering iron and not butt connectors.
Old Nov 27, 2007 | 10:58 AM
Default Re: Push Button Start (SuzukaBlueAP2)
Thanks! Im buying a EP3 this weekend and was thinking of doing that. Know where I can find a push button from?
Old Nov 27, 2007 | 11:18 AM
Probably just get it from a Honda dealership.
I know it's around $35.00 from H and A.
BiG_DeE
Audio / Security / Video
Jul 21, 2010 07:18 AM
epicbeats
Jul 29, 2009 12:59 PM
rolledthatho
Mar 18, 2009 09:22 AM
agCrX
Jun 25, 2004 01:04 PM
