Lighting HID/Xenon kits, Retrofits and Associated Topics
Would a H4 HID kit from an EK fit an EG?
Old Nov 26, 2007 | 11:46 AM
.PLUMMM's Avatar
Default Would a H4 HID kit from an EK fit an EG?
Hey guys whats going on? I am just wondering because, I have a friend who is getting rid of his HIDs and he wonders if i want them. They are H4's and he has them in a 99 civic ex. Thanks in advance for the help!
Old Nov 26, 2007 | 12:11 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
yes they will fit.
Output and beam pattern will be absolutely horrible, though.
HID in stock 92-95 Civic headlights is NOT a good idea at all, due to the prismatic lenses.
Old Nov 26, 2007 | 12:15 PM
.PLUMMM's Avatar
so what do you suggest to make my beam pattern and output better? without retrofitting
Old Nov 26, 2007 | 12:20 PM
Community Builder
I would suggest Philips Xtreme Power H4 bulbs, which put out 80% more light than regular H4 bulbs but draw the same amount of current.
Either that or the new Osram Night Breaker bulbs. I want to say either of those should be around $50/pair, but I'm not totally sure.
Either go that route with halogen or do a retrofit. HID with the stock reflector housings and lenses produces very bad results in all cases.
Old Nov 26, 2007 | 12:22 PM
.PLUMMM's Avatar
good info. I'll definently check it out. Thanks alot!
ps- do you have any pics with the Philips bulbs installed on Egs?
Old Nov 26, 2007 | 12:26 PM
Community Builder
Default Re: (.PLUMMM)
check around in this forum, I've seen a few pics comparing those bulbs to stock.
Old Nov 26, 2007 | 12:33 PM
.PLUMMM's Avatar
I just saw the side by side comparison of those and the philips and the Nightbreaker bulbs look stunning when it comes to high beam
Nightbreaker (left) vs. X-Treme Power (right) -- Low Beam
Nightbreaker (left) vs. X-Treme Power (right) -- High Beam
sireg6
Lighting
Jun 23, 2008 06:30 PM
cycopath
Lighting
May 13, 2008 10:42 PM
.PLUMMM
Nov 27, 2007 04:25 AM
eg:R
17
Jan 22, 2007 04:49 PM
comptechgsr
Aug 9, 2002 07:31 AM
