B18A1 in CRX Radiator Question
Old Nov 26, 2007 | 10:48 AM
Stadler's Avatar
Default B18A1 in CRX Radiator Question
Hello, I am new to this forumn, so I appreciate anything you can tell me. I have an Integra Radiator with a B18A1 engine inside of a CRX. Problem is that the person I purchased the CRX from didn't have the hood down all the way. The hood will not close with this radiator inside. What can I do to make it fit? Should I get stock radiator for CRX? What is recommended to cut if I used the Integra? Also, I read somewhere that ALL aftermarket Radiators are Dual core to accomodate Automatic Trans as well as Manual. My Rex is a Manual. Can I get an aftermarket (third Party OEM Replacement) and have proper cooling? Thanks in advance for all your help
Old Nov 26, 2007 | 11:17 AM
jacoop86's Avatar
Default Re: B18A1 in CRX Radiator Question (Stadler)
you can try and give your radiatior the "gansta lean", or get a crx radiator.
Old Nov 26, 2007 | 11:19 AM
Stadler's Avatar
Default Re: B18A1 in CRX Radiator Question (jacoop86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacoop86 &raquo;</TD></TR><TR><TD CLASS="quote">you can try and give your radiatior the "gansta lean", or get a crx radiator.</TD></TR></TABLE>
HAHAHA!!!! That is TOO FUNNY! Thanks. Do you think the Stock OEM radiator is good enough with this Engine?
Old Nov 28, 2007 | 06:14 AM
jacoop86's Avatar
it'll work. i'm using the stock one with a b16a, works fine.
Old Dec 3, 2007 | 05:13 PM
90tegdude's Avatar
It works fine I have a b series with a single cam rad no problems just make sure to use screw clamps.
Old Dec 3, 2007 | 06:54 PM
StorminMatt's Avatar
If you want a dual core radiator in your CRX, keep in mind that not all Integra radiators will work. From my experience, the stock Integra radiators with the plastic tanks WON'T work. Also, aftermarket Integra radiators that use the same plastic tanks will NOT work. The tanks are FAR too tall, and will interefere with the closing of the hood. But if we are talking about all-metal aftermarket radiators, then you are likely in luck. Many aftermarket radiator companies (like CSF) make a dual core radiator for 1988-1991 Civics. And you can certainly use this for your B16A swap (although you will have to deal with different sized hose nipples). BUT, in order to save money, these companies typically use the exact same radiator, but with bigger nipples, for the Integra. This radiator will fit PERFECTLY, and have the proper size hose nipples for your B-series motor. On the other hand, Civic/CRX fans will not bolt on. You will need to run Integra fan(s).
Old Dec 3, 2007 | 08:40 PM
gursh d's Avatar
it is possible to use an Integra radiator, you'll just have to get a little creative to make it fit. Since you have a b18a, why not get the radiator that was meant for the engine.
Here are a couple how to's:
http://www.performanceforum.co....html
http://honda.hybrids.jp/tech/h...shtml
Old Dec 3, 2007 | 10:28 PM
rd91sib18c5r's Avatar
I'm using a stock radiator on a b18c5 and it's fine.
Old Dec 4, 2007 | 01:29 AM
Default Re: B18A1 in CRX Radiator Question (gursh d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gursh d &raquo;</TD></TR><TR><TD CLASS="quote">it is possible to use an Integra radiator, you'll just have to get a little creative to make it fit. Since you have a b18a, why not get the radiator that was meant for the engine.</TD></TR></TABLE>
Just get an all-metal aftermarket radiator for a 1990-1993 Integra. It drops right in. And the only thing that needs to be changed is the fan(s).
Old Dec 4, 2007 | 02:04 PM
Stadler's Avatar
Default Re: B18A1 in CRX Radiator Question (StorminMatt)
Thanks for all the info. Will this work? Its a Ready Rad.
CRX
http://www.autopartswarehouse.....html
93 Integra
Thanks Again Let me know your suggestions.
PS The integra Radiator is 30 dollars Cheaper
1FSTNDN
Jun 23, 2006 07:17 AM
3s0n3
11
Feb 12, 2006 05:08 PM
Ri5e
Nov 12, 2004 05:18 PM
