car starts then dies think i fixed it but seems to easy.
Old Nov 25, 2007 | 11:48 PM
yeshie's Avatar
Default car starts then dies think i fixed it but seems to easy.
Ok so here is my problem. About a 6 weeks ago I got into my car to go to work at it would not start.
I kinda put it of for as long as I could but I was in a really bad accident in my truck so my car is my only means of transportation.
So I tested my spark and there was none. So I replaced my coil andControl module after I replaced it the car started and ran fine I took it to go get some smokes and some oil.
When I got home the car would not start.
I tinkered around with it for about a week and I noticed that a wire in the distributer was cracked and exposed so I replaced it and now it runs fine had it running for about a hour and drove it around the block.
So my question is could the one little wire that was cracked and exposed could have been the problem? It just seems way to easy.
And it was the wire from the control modal to the coil.
93 da.
Old Nov 26, 2007 | 12:22 AM
LordAphotic's Avatar
that could defitnatly do it if it was exposed enough....
often some of the most anoying problems are the simplest.
Old Nov 26, 2007 | 12:47 AM
yeshie's Avatar
Default Re: (LordAphotic)
just seems like a kick in the face because went over that car like 5 times and to have it be something so easy.....
Old Nov 26, 2007 | 05:06 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (yeshie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeshie &raquo;</TD></TR><TR><TD CLASS="quote">just seems like a kick in the face because went over that car like 5 times and to have it be something so easy..... </TD></TR></TABLE>
sometimes it's the simple things that get you
take it as a lesson learned
Old Nov 26, 2007 | 05:41 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: (AWD Terror)
g/l
moleodonuts
16
Jan 17, 2022 09:59 PM
Noodler
Jun 13, 2009 09:44 PM
citystars41
Jul 28, 2008 06:44 AM
Urban Business
24
Oct 3, 2002 01:11 PM
