91 civc ls swap back bracket problem
Old Nov 25, 2007 | 08:07 PM
endo617's Avatar
Default 91 civc ls swap back bracket problem
I've searched everywhere but all the answers aren't really clear. I was wondering what i would need to do the make it fit on my hatch. I have a 92 ls and hasports but my ls back bracket just went line up i need a detailed instruction on what to do. Thank You
Old Nov 25, 2007 | 08:12 PM
ludesrv's Avatar
Sometimes you have to bash the little lip part of the rear subframe to get it to fit right.
Old Nov 25, 2007 | 08:38 PM
endo617's Avatar
Default Re: (ludesrv)
My friend told me i have to get a b16 back bracket but i'm not sure if its ganna work. Any ideas?
Old Nov 26, 2007 | 12:55 AM
crx_si-r's Avatar
Default Re: (endo617)
if the motor is goin into an EF then u need a 90-93 LS rear bracket so that it will sit perfectly into the engine bay and everything will line up.
Old Nov 26, 2007 | 07:03 AM
ludesrv's Avatar
Default Re: (crx_si-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_si-r &raquo;</TD></TR><TR><TD CLASS="quote">if the motor is goin into an EF then u need a 90-93 LS rear bracket so that it will sit perfectly into the engine bay and everything will line up.</TD></TR></TABLE>
He already said he was using the teg rear bracket and it wasn't lining up.
How does it not line up tho.
phaphon
Jan 24, 2011 07:23 PM
§95HATCH§
Jun 30, 2009 08:13 PM
JokerTypeR
21
Nov 13, 2006 10:38 AM
forcefedferio
May 22, 2006 07:44 PM
4gencivicef9
Apr 27, 2006 05:10 AM
