speedometer not working
Old Nov 25, 2007 | 07:11 PM
zachvirus's Avatar
Default speedometer not working
just did my 4spd to 5spd transmission swap and now my speedometer isn't working. i'm thinking its my speedometer cable(?).
what all could it be or just that?
Old Nov 25, 2007 | 07:18 PM
Suck my DX's Avatar
Default Re: speedometer not working (zachvirus)
vss cable is either not connected or broken...
check the back of the cluster as well as the transmission to see if it is in all the way
Old Nov 25, 2007 | 07:24 PM
VtecSyndrome's Avatar
Default Re: speedometer not working (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">vss cable is either not connected or broken...
check the back of the cluster as well as the transmission to see if it is in all the way</TD></TR></TABLE>
what he said
Old Nov 26, 2007 | 06:46 PM
zachvirus's Avatar
Default Re: speedometer not working (VtecSyndrome)
yup it was my cable. would that cause me to throw a code?
Old Nov 26, 2007 | 07:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zachvirus &raquo;</TD></TR><TR><TD CLASS="quote">yup it was my cable. would that cause me to throw a code? </TD></TR></TABLE>
yep, code 17 which is (drum roll...) VSS.
Old Nov 27, 2007 | 12:37 AM
Suck my DX's Avatar
yeah it would...now if you fixed the issue with the cable and it still throws a code after you reset the ecu, then you may have a problem...i had a similar issue on my old hatch where no matter what i did i couldnt shake my vss code...turns out since i was mixing and matching harness' i wasnt getting power to my speed pulser which is a direct connection to your vss cable...this is in your instrument cluster...i doubt this will be your problem, but if it is, just giving you a heads up on what i have encountered..after i resolved the issue i had no problem with the code 17VSS again...lol well i think so...its been a while since ive even worked on a honda, much less an EF hatch....i guess thats what hapens when you start workin at a domestic shop...lol
GPC91
11
Sep 12, 2012 07:33 AM
dusterbd13
Oct 19, 2009 06:47 PM
memorybox
Jun 10, 2006 12:31 PM
LudeJdm
11
Jun 20, 2005 12:59 AM
JapJunkie
Jun 20, 2004 04:46 PM
