crx ls swap
this topic has been covered 45,231 times. But to answer your question, you have to match the axles to the intermediate shaft. For example, use the 90-93 Integra(DA) Manual halfshaft with the 90-93 axles. There are other options but this one is the easiest! Be sure to remove the dust shields on your hub/knuckle if your using the 90-93 axles. As far as shift linkage, get an aftermarket one modded to fit your car (ef with a b-series swap) or hack up a DA one and make it fit. Also, check out the FAQ version 2 before you post any more questions like this.
Chris2001991
10
Dec 6, 2012 08:49 AM
egboostin6
Jun 20, 2007 06:33 AM
