no vtec???
Old Nov 25, 2007 | 03:34 PM
offroaduseonly's Avatar
Default no vtec???
i have a d16z6 with obd0 converted to obd1 and vtec isn't working at all and cant figure out why. just shimmed the oil pump to make sure it wasn't oil pressure. tried switching solenoid and hard wiring vtec. tried switching ecus that we know work.
Old Nov 25, 2007 | 07:48 PM
VtecSyndrome's Avatar
Default Re: no vtec??? (offroaduseonly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by offroaduseonly &raquo;</TD></TR><TR><TD CLASS="quote">i have a d16z6 with obd0 converted to obd1 and vtec isn't working at all and cant figure out why. just shimmed the oil pump to make sure it wasn't oil pressure. tried switching solenoid and hard wiring vtec. tried switching ecus that we know work. </TD></TR></TABLE>
Speed pulser in the cluster is the most likely cause I have seen for this. the speedo will still work since it's mechanically driven by a cable but the pulser won't send a signal to the ECU which in turn kills vtec engagement, and all w/o any CEL codes too. No way to check it really, just try a known good speedo or cluster and see what that does for you.
Old Nov 26, 2007 | 12:00 PM
Default Re: no vtec??? (VtecSyndrome)
wow didnt know that but i have had two clusters in my car and the one i got right now came out of a car with working vtec.
Old Nov 26, 2007 | 12:19 PM
alscrx's Avatar
what ecu are you using?
Did you hook up a light to see if the vtec selenoid turns on and off?
Old Nov 26, 2007 | 02:12 PM
Default Re: no vtec??? (alscrx)
didnt try the light but thats a good idea. we are using whatever ecu came with the car. we tried a gsr, h22, hondata and another one to see if any of them would work. and they didnt. ill try that light idea though.
Superfly94
Sep 5, 2007 09:55 AM
EK FLY
Aug 24, 2006 05:30 PM
vtecn8ive
22
Aug 3, 2005 01:06 PM
97gsrEK
20
Dec 27, 2004 08:54 PM
HatchBox
40
Nov 23, 2003 05:22 PM
