can i use the stock throttle body and injectors off a 92 f22 motor and use them on a 94 f22b1(SOHC V
also i would like to know if i would need to upgrade anything on the bottom end
well hope this helps because i went through a long process in my f22b1 swap into a 90 accord ex and no you can't use the injectors off them because will idle funny and give problem the 94-97 injectors are longer than the ones in the 90-93 and the throttle bodies are also different so sorry for bustin bubble no will have to find ones off 94 -97
he is correct.....the only possible way to no have a wierd idle using the 90-93 injectors would be to swap in a 90-93 intake manifold and then you run into vtec problems as well as fuel pressure issues ...save yourself a weeks worth of headaches and just get the injectors that are meant for it...as for the throttle body....that wont swap well either...the 90-93 is just the throttle body while the 94-97 has one of the valves on it....hope this helps
This link should help answer your questions about injectors;
http://www.accordinglydone.com/data/injectors.php
no only changes is the ex models compared to the rest of models head changes 2 center exhaust ports closer together and what not but block same crap....
Gezzyvee
May 18, 2015 04:37 PM
4drgsrvtec
Sep 5, 2010 03:32 PM
AlienKrOZ
Nov 12, 2004 06:44 PM
