Need help with ls to gsr swap los angeles!
Old Nov 25, 2007 | 11:25 AM
dc4teggiehatch's Avatar
Default Need help with ls to gsr swap los angeles!
im stuck on the wire harness, i have like 2 sensors extra, its a 94 gsr converted to obd2 into my 96 ls. i bought a obd2 gsr harness and a obd2 ecu to match it. the engine is already in just need help plugging the sensors in... thanks. i hope i get this **** running today...
Old Nov 25, 2007 | 11:27 AM
help a fellow member out
Old Nov 25, 2007 | 11:35 AM
expletive engine harness
Old Nov 25, 2007 | 11:59 AM
Fat Chick Magnet's Avatar
you need to change distributor to obd2, and i believe you need to change the oil pump to obd2.
Old Nov 25, 2007 | 04:40 PM
yeah i did but whats funny is that i have 3-4 extra connectors on the gsr harness i got and they dont plug into anywhere. Is the 94 and 95 gsr motor have more plugs than the 96+ gsr engines?
Old Nov 25, 2007 | 04:41 PM
how about the charcoal canister is on the gsr motor. on my ls its by the battery.
Old Nov 25, 2007 | 04:50 PM
widebodyeg's Avatar
Default Re: (dc4teggiehatch)
there is no crank angle sensor and no knock sensor so those two plugs go nowhere,ur car wont run right without those so u need to get a jumper harness and an obd1 ecu
Old Nov 25, 2007 | 05:54 PM
so you saying the obd2 gsr harness doenst come with knock sensor plugs and crank angle sensor? how does the knock sensor plug on the harness look like.
well im using a obd2 gsr ecu too so, shouldnt it by pass it then?
nick21
Sep 14, 2015 04:18 AM
sebTeggy
Jan 30, 2012 08:26 AM
dc4teggiehatch
Dec 2, 2007 03:00 PM
BbOi0420
Jan 3, 2005 03:16 AM
