Blue or White Smoke? Opinions & Thoughts
Old Nov 25, 2007 | 09:04 AM
Jake1220's Avatar
Default Blue or White Smoke? Opinions & Thoughts
What do you think? The car will do this after sitting overnight, it doesn't start right away. This time it took about 6 minutes of idling before it started. It doesn't have any distinct oil or coolant smell. The inside of the tip has a lot of condensation when this is happening. I do idle very rich until fully warmed up (i.e. 11:1). There is no sign of any smoke after I begin driving. My thoughts are either a mix of condensation and running very rich. Or possibly my valve seals. Or my turbo return line is kinked. Thoughts?
BTW, I am running a cat, and I am currently running horribly rich under boost (i.e. 10:1) because of a tuning issue. Just some extra factors to take into account. Compression is 180 across. I do lose oil. Stock block LS.
It may not look bad in the pictures, but if I start driving after its already doing this I leave a very noticeable trail of smoke behind me. Sometimes I can drive for 10 mins and it won't start until I get stuck at a traffic light.
Old Nov 25, 2007 | 09:14 AM
Audiojb's Avatar
I had a problem similar to this but adding oil fixed it for me as it was damn near empty. After i also had alot of condensation from the tip, but Im not really sure the cause because it cleared up after changing the oil.
Old Nov 25, 2007 | 11:28 AM
turboteg90's Avatar
pm for noodz
Default Re: (Audiojb)
my da used to do that after filling the oil meter all the way up
i change to 15w 50 and no more smoke,well every once in a while when i punch it
a big white cloud shoot out my exhaust
Old Nov 26, 2007 | 06:55 AM
Jake1220's Avatar
Default Re: (turboteg90)
Well I decided to just start it up and go this morning, rather than let it idle. It did not smoke at all. I think that my cat is getting loaded with carbon before it heats up (idling at 11:1) and then burns it all off as soon as it begin to heat up. I need to get my tune corrected, its really pissing me off.
LxSedan
May 15, 2005 07:31 PM
scUba-stEve
Jan 31, 2005 08:38 PM
Eluzion
Aug 25, 2004 01:34 PM
deSigi
10
Aug 24, 2004 08:30 PM
allmotor2000
May 10, 2002 01:56 AM
