Spark Plug Help
I've been using 9-series plugs and I want to switch to NGK Iridium plugs. What is the heat range on those? I need it to be colder than the ones I'm using now. Or...is there something else that is really good for high boost turbo?
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 »</TD></TR><TR><TD CLASS="quote">
What's wrong with NGK 9 copper plugs?
</TD></TR></TABLE>x2
The only reason for using iridium plugs is for the CBR coils because the tip has to unscrew. If you have plug wires or any coil that doesn't need the tip to unscrew, the regular copper core NGK's are fine. And i run colder than 9's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote"> And i run colder than 9's.
liar, u run oem 6's
</TD></TR></TABLE>liar, u run oem 6's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHOAlly »</TD></TR><TR><TD CLASS="quote">
liar, u run oem 6's
No, the OEM's are platinum, i don't use platinum.
liar, u run oem 6's
</TD></TR></TABLE>No, the OEM's are platinum, i don't use platinum.
No, the OEM's are platinum, i don't use platinum. </TD></TR></TABLE>
o yea, u save that for ur teeth!
NGK Iridium part# BKR9EIX stock# 2663....heat range 9. Be careful gaping those things...you will break the Iridium tips off if your not extremely careful. How much power are you making to want to run colder than 9 plugs?
I make a 1000hp.
What are you using then Tony?
I used to use the 9 series plug and put it on the lathe and grind the tip off so that it will fit the CBR. But it takes too much time and it gets to be expensive. Thoughts on something that would cost less?
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryaneg »</TD></TR><TR><TD CLASS="quote">I make a 1000hp.
Thanks!</TD></TR></TABLE>
what car is yours ?
what car is yours ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I make a 1000hp.</TD></TR></TABLE>
Not trying to bash but you make 1000hp and cant figure out yourself what spark plugs to use...
Modified by PHDZINE at 10:40 AM 11/27/2007
When I use the NGK Iridium...it seems like I have to change them out less often than the regular V power racing NGK's but at the cost of 10X more than the V power racing...I stick with the regular V power because it is more cost efficient.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">I swap mine every couple of events or so.</TD></TR></TABLE>
Ever tried one of those spark plug refreshening machines?
Ever tried one of those spark plug refreshening machines?</TD></TR></TABLE>
My roommate uses one of those for his Harley race bike stuff & swears by it. I personally didn't believe it but his race bike runs flawlessly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.S.AKIMOTO »</TD></TR><TR><TD CLASS="quote">
My roommate uses one of those for his Harley race bike stuff & swears by it. I personally didn't believe it but his race bike runs flawlessly. </TD></TR></TABLE>
Rota mentioned it to me about 2 months ago and I thought it was the most retarded thing I have ever heard.... but when you pay $10-14 a plug (Iridiums) then it may be worth it.
