Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Using 93 octane gas?
Old Nov 25, 2007 | 08:12 AM
dwojno's Avatar
Default Using 93 octane gas?
Does anyone now if I will gain any power on an 07 civic ex if I use 93 octane gas instead of 87?
Old Nov 25, 2007 | 09:09 AM
AutoXer's Avatar
Default Re: Using 93 octane gas? (dwojno)
No, you won't get any benefit at all. All octaine does is increase the fuels resistance to detonate. The higher the octane the less likely it is to detonate early which causes 'knocking'. That's why it is used in higher compression / performance engines.
Old Nov 25, 2007 | 09:49 AM
RICO_'s Avatar
NO MERCY!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwojno &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone now if I will gain any power on an 07 civic ex if I use 93 octane gas instead of 87?</TD></TR></TABLE>
NOPE!!!!!!!!!
And octane boosters from Walmart or any other place won't increase power either.
Old Nov 25, 2007 | 12:28 PM
JDMsam.'s Avatar
Default Re: Using 93 octane gas? (RICO_)
that pretty much raps it up.
Old Nov 25, 2007 | 03:56 PM
24boosted's Avatar
Default Re: Using 93 octane gas? (JDMsam.)
Not to mention it won't completely combust properly. Higher octane meant for high compression.
Old Nov 25, 2007 | 05:09 PM
AutoXer's Avatar
Default Re: Using 93 octane gas? (24boosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24boosted &raquo;</TD></TR><TR><TD CLASS="quote">Not to mention it won't completely combust properly. Higher octane meant for high compression. </TD></TR></TABLE>
Not neccessarily. Higher octane fuel has a higher flash point. Due to this the higher octane fuel is more likely to burn completely than a lower octane. Due to engine technology and better fuel formulation it's a bit of a moot point though. Bottom line is to use the octane specified in your manual. Using higher octane won't do anything but cost you more money.
SlowEJ8
48
May 2, 2009 06:44 AM
socallmechris
10
Jan 12, 2008 04:42 PM
WarpedSportzKid
Feb 8, 2007 01:11 PM
4DRmafia
Sep 14, 2004 05:14 PM
genetsang
Jun 11, 2003 09:49 AM
