temp gage
Old Nov 25, 2007 | 06:54 AM
folta2169's Avatar
Default temp gage
i am havin trouble with my temp gage not workin, but yesterday i left my car runing for like 45 mins. and when i got in my car the gage was working, but after i started driving the car after a few mins. the gage went back to not working. wat would be the problem. and my gas gage isn't working either but i think it is the fuel pump piece that makes that not work. but anyway the temp gage help please.
Old Nov 25, 2007 | 07:08 AM
gourley's Avatar
Default Re: temp gage (folta2169)
I have the same problem, when I start my car, my temp guage will work and goto normal temp, then once I start driving it goes back down to cold. Hope you find the answer
Old Nov 25, 2007 | 09:24 AM
superex87's Avatar
I also have a similar problem, car warms up then temp guage randomly moves between cold and normal operating temp, when it does this it does it very slowly
Old Nov 25, 2007 | 12:49 PM
manicmechanic's Avatar
hey guys i have the same problem. i have to clusters thought. 1 is the si cluster that i have in now and the other is just the standard. tomorrow i am going to try the standard cluster see if it does the same thing with that 1. i am not getting it eather? i will have to let you guys know what happens.
Old Nov 26, 2007 | 08:16 AM
well it has nothing to do with the gauge. i am 98% sure its the t-stat. if i do get one today from acura and put it in i will let you know. i am running a b18 in my hatch.
Old Nov 26, 2007 | 11:30 AM
slaya's Avatar
hha i got the same problem 2 it will work fine but when i but when i push in the clutch and start taking off it goes crazy
Old Nov 26, 2007 | 06:42 PM
Hanmin's Avatar
my car does this too.
Old Nov 28, 2007 | 02:28 PM
change the t-stat. pulled mine out and it was stuck part way open.
Old Dec 3, 2007 | 03:14 PM
superex87's Avatar
Default Re: temp gage (manicmechanic)
I changed my thermas sta and it fixed the problem, Iv also hear that it can be a grounding issue
Asmooh
18
Apr 15, 2014 07:05 AM
Fatty Wagovan
May 4, 2012 11:38 AM
CrisEK
Sep 30, 2005 04:27 PM
FourthGenHatch
May 10, 2003 11:36 PM
