Honda S2000 Honda S2000
Starter "sticks" for a moment after starting ('04 S2k)
Old Nov 25, 2007 | 06:32 AM
fsp31's Avatar
Default Starter "sticks" for a moment after starting ('04 S2k)
Just wondering if anyone else has experienced this...
The starter seems to stay engaged for just a moment after the engine fires up. The result is the starter getting "spun" pretty good for about a quarter of a second. This only happens on cold days and when the engine is cold. Engagement sounds great and the starter works well, but I'm worried about undue wear on the starter.
Any suggestions on how I may resolve this before the starter dies?
Thanks!
Old Nov 25, 2007 | 05:03 PM
KingVR's Avatar
Default Re: Starter "sticks" for a moment after starting (fsp31)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fsp31 &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering if anyone else has experienced this...
Thanks!</TD></TR></TABLE>
This may surprise you, but it is in fact NOT the starter.
It's actually the timing chain tensioner not having enough pressure on the slack-side of the chain since oil pressure has not been primed after it bleeds down while it's off, and is more prone to occur when the car is driven in cooler weather, and when it sits longer than a day at a time.
Solution: buy/install a new timing chain tensioner...or wait for me to produce a manualy adjusted timing chain tensioner that I have in the works.
Old Nov 26, 2007 | 04:49 AM
Import_Fan's Avatar
Default Re: Starter "sticks" for a moment after starting (KingVR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingVR &raquo;</TD></TR><TR><TD CLASS="quote">
Solution: buy/install a new timing chain tensioner...or wait for me to produce a manualy adjusted timing chain tensioner that I have in the works.</TD></TR></TABLE>
Never knew this.
Old Nov 26, 2007 | 08:02 AM
ReddotsS2K's Avatar
what he said
Old Nov 26, 2007 | 09:51 AM
KingVR's Avatar
Default Re: Starter "sticks" for a moment after starting (ReddotsS2K)
BTW,
What would the popularity of my manually-adjusted tensioner be anyway? I was going to make at least a dozen, but this and a few other ideas have me thinking of literally becoming a manufacturer of various products.
The OEM unit that HardTopGuy sells constantly sell for about $156 I think...I could make/sell my manual unit for MUCH LESS, with the added benefit that you will NEVER EVER have to worry about replacing it. I put a new OEM unit in mine a few months ago and while it DID eliminate the noise that the OP talked about, I still have a noise that most are not even aware of. The noise occurs and is audible between 4k RPM and 6k RPM, most prominent around 5k RPM. I recognize this from when I had my Honda CBR 600 F4 (NOTORIOUS for this problem that Honda will not fix) and my S has the same exact rattle sound. You can hear it when you accelerate gradually through the 4k - 6k RPM range. If you decelerate it will not produce the sound because the 'slack-side' of the chain becomes tightened.
I don't know if other people are getting this same sound, or it's something I have due to having 100k+ miles on my car. I'd like to hear how many others currently have this sound present on their S, or have in the past.
Old Nov 26, 2007 | 04:28 PM
KingVR's Avatar
Nothing?
Perhaps I could have a Japanese guy bless them so that they are "Kosher JDM", eh?
Old Nov 26, 2007 | 05:21 PM
ReddotsS2K's Avatar
i dont really know, i havnt pulled mine apart to change the tensioner yet, but i suppose if it never went bad like the oem ones it would be pretty popular
Old Nov 26, 2007 | 05:47 PM
Black S2K's Avatar
yea dude if it was good quality I would be all about it.
Old Nov 28, 2007 | 03:42 PM
fsp31's Avatar
Wow! I had never considered the timing chain tensioner. This motor has about 50k miles on it. I'll take a look at it.
Regarding the manual tensioner, how critical is the "torque" placed on the chain? Does it have to be very precise? Can I use a torque wrench? (I'm not very familiar with f20's... still stuck in a b series time warp)
Old Nov 28, 2007 | 07:47 PM
KingVR's Avatar
Well, I haven't made the first batch yet, but it works like this:
1. INSTALL UNIT
2. Adjust threaded shaft until it starts to apply tension
3. Start engine and rev to 5k RPM (or wherever you hear the chain go into harmonics/rattle)
4. Continue to adjust tension until the harmonics/rattling stop/go away
5. Tighten Locking Nut and enjoy!
...simple as that, and it will never go bad on you down the road.
Old Nov 29, 2007 | 06:05 PM
Techno Tonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingVR &raquo;</TD></TR><TR><TD CLASS="quote">Well, I haven't made the first batch yet, but it works like this:
1. INSTALL UNIT
...simple as that, and it will never go bad on you down the road.</TD></TR></TABLE>
well... I dunno if i want to be a guinea pig for your timing chain... but....upload some pictures, and maybe we wil talk
Old Nov 29, 2007 | 07:23 PM
KingVR's Avatar
Default Re: Starter "sticks" for a moment after starting (Techno Tonis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techno Tonis &raquo;</TD></TR><TR><TD CLASS="quote">
well... I dunno if i want to be a guinea pig for your timing chain... but....upload some pictures, and maybe we wil talk </TD></TR></TABLE>
Don't worry. Myself and JDM Knowledge will be Pig'n it up first.
Old Nov 30, 2007 | 12:51 AM
scubba's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingVR &raquo;</TD></TR><TR><TD CLASS="quote">BTW,
I don't know if other people are getting this same sound, or it's something I have due to having 100k+ miles on my car. I'd like to hear how many others currently have this sound present on their S, or have in the past.</TD></TR></TABLE>
Sign me up
Old Dec 1, 2007 | 08:36 PM
neeman77's Avatar
its not the timing chain tensioner its the starter...the starter bendix sicks and does not retract from the flywheel. You need a new starter. I had the same problem and replaced the TCT for no reason.
Old Dec 2, 2007 | 03:13 PM
KingVR's Avatar
Default Re: (neeman77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neeman77 &raquo;</TD></TR><TR><TD CLASS="quote">its not the timing chain tensioner its the starter...the starter bendix sicks and does not retract from the flywheel. You need a new starter. I had the same problem and replaced the TCT for no reason.</TD></TR></TABLE>
Be careful...while yes, it CAN also be the starter, but it would be more frequent if it truly were the starter. The TCT will usually only make it's noise when the car has sat for more than one day, and more frequent when the temps are cooler.
I replaced my TCT and that "starter sound" went away, but I still get the 4k - 6k RPM rattle.
Old Dec 3, 2007 | 09:30 AM
M.A.R.C.'s Avatar
Default Re: (KingVR)
you know... i've seen this thread for a while now and i ignored it until now. i used to have the same problem on my old ap1... would happen randomly but it makes sense now. learn something new every day
Old Dec 4, 2007 | 11:20 AM
mrjingles8705's Avatar
One word... SEARCH.
Old Dec 4, 2007 | 11:33 AM
Default Re: Starter "sticks" for a moment after starting (mrjingles8705)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrjingles8705 &raquo;</TD></TR><TR><TD CLASS="quote">One word... SEARCH. </TD></TR></TABLE>
uh... what?
HokieS2K
Honda S2000
Feb 16, 2009 05:02 PM
h22a_black
Feb 13, 2008 06:12 AM
WTB AUTO EK
May 12, 2005 06:46 AM
Sukebei Oni
Mar 16, 2003 01:21 AM
