Car overheating need help!!!
Old Jun 25, 2002 | 09:19 AM
FOrSfEd's Avatar
Default Car overheating need help!!!
Car overheats only when on the highway on long trips but never moves when driving in town. Car has no thermostat so it shouldn't be that. It also has a upgraded radaitor from the stock sohc vtec to the dua core dohc vtec.
Lee
Old Jun 25, 2002 | 09:57 AM
Houston Hatchback's Avatar
Default Re: Car overheating need help!!! (Rex2nv)
you can go to the store and get some liquid call water wetter.. i really help you just drain your anit freez out and put nothing but water in there and put in the water wetter in and bam you got a cold car. also put your thermostat back in cause when you use this its take alot to warm the car up... there my 02 cents and its worked for me and i hope it works for you..
Old Jun 25, 2002 | 10:03 AM
PhuckinHondas's Avatar
you need to put the thermostat back on
i dont think the water/coolant is cooling off enough its running straight through
try putting one on
Old Jun 25, 2002 | 11:18 AM
4g4me's Avatar
YEs, you need the thermostat. Try that, the coolant system is getting fatigued too early in the cooling stage.
olddohc
Dec 18, 2011 08:35 PM
primetime
Aug 22, 2010 07:00 PM
vinceiscoo
12
Sep 5, 2008 11:02 AM
Hondaciv95VX
Jan 13, 2005 07:21 PM
Andrew Sites
Oct 7, 2001 08:36 PM
