Turn Signal/Hazard Relay on '96 Accord
Old Nov 24, 2007 | 08:55 PM
brose's Avatar
Default Turn Signal/Hazard Relay on '96 Accord
Is there an easy way to remove the turn signal/hazard relay? I have a '96 Accord, 4 cyl sedan. This is the relay on the under-the-dash fuse panel next to your left foot. This relay is directly above the Integrated Control Unit, and to the left of the blower motor relay. Even with the blower motor relay removed (which was easy), the turn signal relay won't budge. I removed one at a junkyard by prying it away from the fuse box, but broke the relay casing in the process. I assume it's held in place by some clip, but couldn't get it to release. Any replies would be gratefully appreciated.
Thanks in advance,
Old Nov 30, 2007 | 08:12 PM
PnX-R's Avatar
Default Re: Turn Signal/Hazard Relay on '96 Accord (brose)
Hmm.. Not too sure but, relays usually have one clip on each side. I usually try to pop at least one clip and wiggle it free.
Tie Ee Fei
10
Jan 11, 2019 09:34 AM
bulljaso
Aug 16, 2018 12:09 PM
fanchyna
Jun 29, 2012 07:57 PM
thehondaguru
Jan 11, 2009 04:27 AM
gliaw
Oct 12, 2003 04:53 PM
