Built turbo motor swap Vtec 3500 firm
Selling fully built turbo motor fresh rebuilt zero miles need to sell this is almost complete swap needs 3 things must sell
CP 8.5-1 pistons and rings
Carrillo rods
Type R crank
type R oil pump (Brand new from Acura)
Federal Mogul main bearings
OBX oil pan 5 qt with 1/2" bungs
Cometic Head Gasket
Skunk2 stage2 turbo cams
Skunk2 springs and retainers
Arp head studs and main studs
Head is ported and polished with a 3 angle valve job
needs cam seals i have all other gaskets
Skunk2 intake manifold with stock ls throttle body(ported polished to head)
AEM 5 bolt cam gears
Greddy Timing Belt
stock type R crank pully
stock type r dizzy obd2
Type R fuel rail injectors and reg (might be able to even throw in stock type R pump amost new)
Gsr vave cover(not the greatest condition needs to be blasted and painted but its cut for the cam gears)
ls trans 5speed with linkage and type r shifter
you will only need clutch and flywheel and a turbo set up
[IMG][/IMG]
Modified by meric0786 at 5:42 PM 11/25/2007
Carrillo rods
Type R crank
Cometic Head Gasket
Greddy Timing Belt
[IMG][/IMG]
homicydalboy
Dec 27, 2008 12:37 PM
homicydalboy
Jan 22, 2008 10:00 AM
Playero713
Dec 22, 2004 10:21 AM
