Suspension & Brakes Theory, alignment, spring rates....
Question about Skunk 2 Extended Lugnuts..
Old Nov 24, 2007 | 05:37 PM
Manolo's Avatar
Default Question about Skunk 2 Extended Lugnuts..
I got a set but im running them on my OEM swirleys, I was wondering if this is ok. I dont remember but i think i read somewhere that aftermarket lugs are only for aftermarket rims??
Old Nov 24, 2007 | 09:40 PM
mormonboy's Avatar
Default Re: Question about Skunk 2 Extended Lugnuts.. (Manolo)
https://honda-tech.com/zerothread?id=1975333
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
The only issue I can think of (aside from the extra weight) is making sure the lug nuts have the right seating area for your wheels. The seating area is the area where the lug nut comes into contact with the wheel, as shown at the bottom of each of the lug nuts in the illustration below.
Most Honda/Acura wheels have a ball-shaped (radius) seating area and need lug nuts which also have a ball-shaped seating area. Most aftermarket wheels, and most aftermarket lug nuts, have a tapered (conel) shaped seating area. You need to use lug nuts that have the same shape seating area as your wheels do.
Old Nov 26, 2007 | 06:40 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manolo &raquo;</TD></TR><TR><TD CLASS="quote">I got a set but im running them on my OEM swirleys, I was wondering if this is ok. I dont remember but i think i read somewhere that aftermarket lugs are only for aftermarket rims??</TD></TR></TABLE>
No it's not okay. Aftermarket lug nuts on OEM wheels (or vice versa) is very unsafe, for the reason posted above. Use OEM or OEM-style lug nuts w/ OEM wheels, nothing else.
Old Nov 26, 2007 | 07:45 AM
gabebauman's Avatar
Default Re: Question about Skunk 2 Extended Lugnuts.. (PatrickGSR94)
Don't let this be you:
http://www.youtube.com/watch?v=kyMDNzhfwn0
http://www.youtube.com/watch?v=8guSoWOafkI
Old Nov 26, 2007 | 08:13 AM
Community Builder
I don't know about the rally car, but the RX-7 was not a result of incorrect style of lug nuts, but rather lugs that were too short and didn't engage all of the threads on the studs.
Old Nov 26, 2007 | 01:43 PM
themikewoo's Avatar
Man that's harsh. I thought the RX-7 lost his wheels because of incorrect torque but short lug nuts makes more sense.
Old Nov 27, 2007 | 08:30 AM
milkmanLCA's Avatar
Default Re: (themikewoo)
you mean his studs were too short?
PowerPig
Aug 11, 2008 05:05 PM
dafuzzbudd
Jul 12, 2008 09:20 AM
accorkie
Jul 31, 2007 09:23 AM
G'Funk
May 6, 2007 09:17 AM
iixerOii
Nov 19, 2006 09:45 AM
