ok to use 220 grit sandpaper on block?
its ok to use that.. problem is the small metal particles u prob dont see fall down in the oil chambers and get to the bearings so make sure u clean it out really really good with brake clean and all .. then pour some clean oil down to help out after its clean
sanded it on a engine stand with the motor upside down so debris would not fall down..i might touch it up with 400 grit.. thanks for the info
tr0n9h
Jul 11, 2006 11:43 AM
DeDonDeRosa
Apr 4, 2003 11:06 AM
