Powdercoating Aluminum Boost Tubes and Intake Manifold?
Old Nov 24, 2007 | 04:44 PM
Justin Olson's Avatar
Default Powdercoating Aluminum Boost Tubes and Intake Manifold?
Are there some good reasons for me to not have my boost tubes and intake manifold powder coated? I have a good hookup through my work to get them done for free, so I figured I'd do it.
My worry is the insulation the powder coat would add to the intake and charge pipes.
Also, Would I be more prone to blowing off couplers? I could see the powder coat being slick and hard to grab with the coupler?
Justin
Old Nov 24, 2007 | 05:00 PM
DESTROYER's Avatar
Eh, the powdercoat really isn't too slick actually. I have done it to a few setups, it shouldnt be bad at all.
Old Nov 25, 2007 | 05:49 AM
NJIN BUILDR's Avatar
Default Re: Powdercoating Aluminum Boost Tubes and Intake Manifold? (Justin Olson)
The insulation properties are a plus with charge pipes and intake manifold.As long as your charge pipes are bead rolled you will be fine.
Old Nov 25, 2007 | 06:59 AM
DESTROYER's Avatar
Default Re: Powdercoating Aluminum Boost Tubes and Intake Manifold? (NJIN BUILDR)
I didnt have a bead roller at the time, but I had the powdercoaters use a textured powdercoat on the last 1.5" of each tube.
Old Nov 25, 2007 | 08:09 AM
dave@passenger's Avatar
Default Re: Powdercoating Aluminum Boost Tubes and Intake Manifold? (DESTROYER)
Powder coating is fine, we used to do powder coating in house and coated intake manifolds and charge piping all the time, it doesn't really make the material any more "slick" than it naturally is, and it is a joke of an insulator. Go for it man.
Old Nov 26, 2007 | 03:45 PM
Default Re: Powdercoating Aluminum Boost Tubes and Intake Manifold? (dave@passenger)
Well, I'm getting ready to powdercoat my valve covers, intake manifold and boost tubes. Do I need to use high temp powdercoat???
Justin
Old Nov 26, 2007 | 05:54 PM
2kjettaguy's Avatar
No high temp... Powdercoat is essentially a thin layer of plastic which melts at around 400°. You only need to do high temp on exhaust parts. The high temp stuff isn't high-temp enough for anything on the exhaust between the head and the end of the cat.
Evan
JDMCRX
Welding / Fabrication
Sep 14, 2008 02:40 PM
civicnar
Mar 14, 2005 07:32 AM
9seccivicsi
Jun 22, 2004 12:49 PM
-Trinitron-
Sep 18, 2003 08:57 AM
