How to fill or remove dents off rims
Old Nov 24, 2007 | 03:17 PM
rbeharry's Avatar
Default How to fill or remove dents off rims
I've got a set of aluminum rims with bad curb rash and a few dents, how can I fill or remove these dents?
Old Nov 25, 2007 | 12:15 AM
Doostur's Avatar
Bring them to a shop
Old Nov 25, 2007 | 05:40 PM
rbeharry's Avatar
Default Re: (Doostur)
i want to do it myself, the sanding and painting isn't a problem, but if i have to fill them, i don't know what to use
Old Nov 25, 2007 | 07:10 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: (rbeharry)
i think bondo would work? and sanding them down real good i guess..
Old Nov 25, 2007 | 09:47 PM
NW Classic Honda's Avatar
Default Re: (PhantoM.DA)
Bondo? Thats funny!!!
Old Nov 26, 2007 | 05:54 AM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: (jdmda7)
Ive seen people use bondo before i dont know for sure if you should or can be using it
Old Nov 27, 2007 | 12:55 PM
Hanmin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmda7 &raquo;</TD></TR><TR><TD CLASS="quote">Bondo? Thats funny!!! </TD></TR></TABLE>
if not bondo, then what are you supposed to use?
Old Nov 27, 2007 | 01:49 PM
Default Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote">
if not bondo, then what are you supposed to use?</TD></TR></TABLE>
Bondo will flake and crack off! Weld and grind smooth, weld and grind smooth... Ask any wheel repaire shop!
Old Nov 27, 2007 | 03:52 PM
McLaren Int'l's Avatar
Bondo will flake and crack off! Weld and grind smooth, weld and grind smooth... Ask any wheel repair shop! </TD></TR></TABLE> qft
Old Nov 27, 2007 | 04:18 PM
4drtimmy's Avatar
Bondo will flake and crack off! Weld and grind smooth, weld and grind smooth... Ask any wheel repaire shop! </TD></TR></TABLE>
what is it like 75 or more to get a wheel repaired these days?? spend the money the youll be happier with the results..
Old Nov 29, 2007 | 07:45 PM
turbosx's Avatar
Default Re: (4drtimmy)
theye charge 25 depending how bad it is
Old Nov 30, 2007 | 02:07 AM
hellakapps's Avatar
Default Re: How to fill or remove dents off rims (rbeharry)
what about quick steel, it's a putty epoxy, it might work but it's just a suggestion
Old Nov 30, 2007 | 03:03 AM
Chiodos's Avatar
Default Re: How to fill or remove dents off rims (hellakapps)
^^Anything besides a Weld will just flake and crumble off!
Have to do this^
Old Nov 30, 2007 | 08:36 AM
rbeharry's Avatar
Default Re: (McLaren Int'l)
I can weld the aluminum alloy? Could i sandblast the paint off these?
Old Nov 30, 2007 | 09:02 AM
Hanmin's Avatar
Heavy duty paint stripper.
Old Nov 30, 2007 | 10:09 AM
Chiodos's Avatar
Ya use aircraft paint stripper^^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbeharry &raquo;</TD></TR><TR><TD CLASS="quote">I can weld the aluminum alloy?</TD></TR></TABLE>
http://www.lincolnelectric.com...m.asp
Old Nov 30, 2007 | 04:59 PM
old man neri's Avatar
I think you are just best off going to a pro, pay the bucks, get it done right the first time. Why take chances of a wheel coming apart on the highway because of a bad weld or something.
Old Dec 1, 2007 | 08:00 AM
Hanmin's Avatar
its just curb rash, I don't think your wheel will break apart. Doing it yourself = more experience=]
Old Dec 4, 2007 | 07:00 PM
rbeharry's Avatar
so i've sanded them down already, should i use high heat paint or high heat primer, i want to use spot and scratch filling primer but i'm not sure if it would hold??
Rikaro
Mar 12, 2008 04:09 PM
canttouchthiscrx
50
Jul 3, 2007 02:40 PM
invisible
Jan 27, 2007 10:01 AM
xEYEDEAx
Jul 16, 2005 06:48 PM
Screaming Vtec
Feb 27, 2005 06:29 PM
