2000 civic si black, b16a,jdm v4d tranny st.louis mo
2000 civic si
98000 miles
clean title
black
installed b16a engine bought from hmotorsonline.com
before install replaced all the following with oem honda parts
hondata manifold gasket
oil pan gasket
rear main seal
polit bearing
head gasket
water pump
primary and secondary 02 sensors
timimg belt
acc belts
ect sensor
fan switch
thermostat
oil pump with obd2 crank sensor
new dizzy
fuel filter
plugs
wires
tranny is a jdm gsr tranny code s80 v4d. bought an had quaife lsd installed.
act stage 2 clutch. installed with new engine and installed new flywheel.
about 10k miles ago i had a new oem factory exhaust system installed
engine was complety updated for use with the factory obd2 system
car is smog legal as will pass emissions.
only mods to the car are suspension skunk2 pro series coilovers and struts
progress rear swaybar
ingalls front control arms
rear camber corection kit
new brembo blank rotors
aem brake pads
all factory options work except powersteering was removed but will come with the car for reinstall.
ice cold a/c
car runs and drives great and is a perfect daily driver.
engine and tranny were put back in with time no hack job on wiring an engine parts
harness was not just thrown on i carefully installed in back on the engine with all correct brackets an such no cut plug ends or butt connectors or anything of that sort on the motor.
car runs drives and idles perfect
Have recipts for everything
8500
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Modified by mooook at 11:01 PM 11/25/2007
Modified by mooook at 4:33 PM 12/2/2007
98000 miles
clean title
black
oil pan gasket
rear main seal
polit bearing
head gasket
water pump
timimg belt
acc belts
ect sensor
fan switch
thermostat
new dizzy
fuel filter
plugs
wires
aem brake pads
ice cold a/c
8500
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
has 98k on the body. hmotors says motor is said to have between 25-35k miles but you know how that goes with jdm motors who knows...
[IMG][/IMG]
[IMG][/IMG]
