Tail 35mm and 38mm wastegate interchangeable?
I'm running the older stlye 35mm tial wastegate and am trying to find a stiffer spring for it and was wondering if a spring from a 38mm would work.
Or if anyone has any idea on where to get a 10psi spring from let me know.
Thanks
Thanks
yep, the boost pressure will change slightly from what the spring is rated
say you have a 15psi spring, it might make it a 13-14psi spring
all tial wastegate springs are interchangeable, but the spring pressure will change because of the valve surface size changing
