DA spring/struts fit on ef?
Old Nov 24, 2007 | 06:54 AM
freakasis's Avatar
Default DA spring/struts fit on ef?
will they?
thnax
Old Nov 24, 2007 | 06:57 AM
oldskool88291's Avatar
Default Re: DA spring/struts fit on ef? (freakasis)
if the rear discs bolt right on im sure they will too as long as u use the lower control arm form the integra, but if u do use the lower control arms i think ur rear wheels will stick out a 1/2 in to and inch out farther. but like i said im sure they will meaning i never tired it
Old Nov 24, 2007 | 09:12 AM
justseeingifitistaken's Avatar
Default Re: DA spring/struts fit on ef? (oldskool88291)
they 'fit' but have a higher spring rate
Old Nov 24, 2007 | 01:23 PM
freakasis's Avatar
thanx
Old Nov 24, 2007 | 06:38 PM
AK_CRX's Avatar
Default Re: (freakasis)
and they are TALLER! your car will be off-road ready with those. Not for sure but I almost think the front struts won't fit into the fork, you'd need a da fork pretty sure... In more ghetto times I have ran integra rear shocks with cut springs to achieve a stock ride height on a crx, even cut they are way stiffer than crx springs. But seriously just cause I was ghetto doesn't give you an excuse aight?
akshn1
Feb 16, 2010 05:47 AM
Dee A Nine
Suspension & Brakes
May 11, 2005 01:18 PM
NINJASPY
Sep 19, 2003 11:56 PM
curiousgpnoy
Apr 30, 2003 01:53 PM
ITR764
10
Oct 7, 2002 04:59 PM
