just bought a crx corner lights turn signals arent working
ok i need help and let me kno what u think could be wrong there was 2 relays chillen in my car looked like they were burnt so i took them out my corner lights and my turn signals on my cluster dont even come on or make nosie anymore what can it be anyone help if u in socal hit me up if someone can fix this i will pay them.
Make sure first that your hazard button is plugged in. Next check the relay on the underdash fusebox. It should have 'turn' or something to that order marked by it. Next make sure your fuses are good. I had this same problem. It was the relay
If I read that correctly, you removed two relays? Did you replace or just remove em? If you didn't replace, that's probably the cause of your problems.
neozero999
14
Oct 22, 2008 02:37 PM
