question about wiseco second ring
Old Nov 23, 2007 | 10:07 PM
98vtec's Avatar
moderator emeritus
Default question about wiseco second ring
on the pink slip regarding the rings, it states that i need to have the second ring with the marked side face up. same with the top ring. well the top ring had markings "N" so i put that face up, but the second rings had no markings. Which kind of bugged me considering the slip said there would be a marking...
any thoughts please?
Old Nov 24, 2007 | 06:11 AM
98vtec's Avatar
moderator emeritus
Default Re: question about wiseco second ring (98vtec)
Old Nov 24, 2007 | 07:24 AM
funk.regulator's Avatar
If I can remember corectlly on mine, one side of the ring is flat and the edge on the other side is concaved (best explanation I could come up with). Put the flat side down.
Old Nov 24, 2007 | 08:22 AM
98vtec's Avatar
moderator emeritus
Default Re: (funk.regulator)
after further inspection, i took a flashlight to the rings and found the marking wiseco was referring to. its very very faint...but its there.
it has the same "N" marking as the top ring.
however:
http://www.wiseco.com/PDFs/Wis...s.pdf
i have the XX ring set and i dont see the tapers that are supposed to be on the ends and there is definitely no "hook" in the ring...
Old Nov 24, 2007 | 08:24 AM
Natural Aspirations's Avatar
Default Re: (98vtec)
Mine was there but very faint, it just has a small groove around the outside of the ring.
Old Nov 24, 2007 | 08:50 AM
Lubo_25's Avatar
for my cp's it said if it has numbers or markings face the rings up if nothing is there either side up...or some **** like that lol...thats ackward that there is no hook in the second ring
aaronhume
Mar 12, 2007 07:54 AM
97grnrs
Feb 8, 2007 11:22 AM
