89 civic hatch si
225k chassis
CLEAN TITLE
sunroof
oem cd player
owner since 2003
bone stock d16z6 approx 100k, just had leakdown test at Whitfields(whitfieldracing.com) 3 weeks ago-tested 15% 15% 10% 15%(have receipt)-they said it was in excellent shape. compression also just tested by SoKwik(sokwik.com) 2 weeks ago and tested 195 195 195 195
SoKwik also redid the obd1 conversion and fixed ALL codes=no check engine light
also put in new o2 sensor and reset timing.
things done in Jan 07- axles, rotors, pads, master cylinder, starter, waterpump, thermostat, timing belt, all new gaskets, new oem flywheel, exedy stage 1 clutch, battery.
has tokiko blue shocks, h&r sport springs, dc short shifter, alarm, and tanabe racing medallion exhaust(the quiet one). body has no dents except a small hit on rear(truck back into my driveway). rear interior is flawless, drivers seat has usual wear, passanger is starting to wear.
3k on stock wheels and hood.
will sell with axis maglites with kumho spt(2) and 712(2) with 80% tread and VIS carbon fiber hood for an extra 700.
CLEAN TITLE
sunroof
oem cd player
owner since 2003
also put in new o2 sensor and reset timing.things done in Jan 07- axles, rotors, pads, master cylinder, starter, waterpump, thermostat, timing belt, all new gaskets, new oem flywheel, exedy stage 1 clutch, battery.
sleepless247
Aug 31, 2005 08:28 PM
