my 93 lude will run for 2 min then cut off. need help
Old Nov 23, 2007 | 12:47 PM
bobe14's Avatar
Default my 93 lude will run for 2 min then cut off. need help
at first it would not go pass 3k rpm then after 2 or 3 minute it will cut off, if you try imediately to re start the car it will not. but if you wait several min it will but it will cut off several min after. those anybody have a clue of what it could be, i will apreciate any help.
Old Nov 23, 2007 | 12:58 PM
Hawkze_2.3's Avatar
Default Re: my 93 lude will run for 2 min then cut off. need help (bobe14)
Year of your car? Model? Engine? Details maybe?
Old Nov 23, 2007 | 01:01 PM
bobe14's Avatar
Default Re: my 93 lude will run for 2 min then cut off. need help (Hawkze_2.3)
1993 prelude si it has a h23 and is manual trans, cold air intake, nology wires, header, full exhaust
Old Nov 23, 2007 | 01:04 PM
Hawkze_2.3's Avatar
Are you getting any check engine lights? It could be your main relay, ingnition switch ignitor, etc...probably main relay though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobe14 &raquo;</TD></TR><TR><TD CLASS="quote"> nology wires
I'd put some stock or NGK wires on there, those 'ground straps' are useless.
Old Nov 23, 2007 | 01:09 PM
bobe14's Avatar
not enough time for the check engine to come on it cuts off alsoif i try to rev the engine it sounds like it's missfiring.
Old Nov 23, 2007 | 01:12 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobe14 &raquo;</TD></TR><TR><TD CLASS="quote"> alsoif i try to rev the engine it sounds like it's missfiring.</TD></TR></TABLE>
That could be your timing. Check both ignition timing and cam timing.
Another easy thing to do would be to replace spark plugs, distributor cap and rotor and see if that helps.
Old Nov 26, 2007 | 03:25 PM
bobe14's Avatar
it's not the timming, plugs wires and the hole distributor is brand new, i hear a weird noise comming from the intake control selenoid i was thinkin a sensor possibly or the fuel pump or mayhbe the ecu. don' know is relly crazy what the car is doing.
Old Nov 27, 2007 | 07:51 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobe14 &raquo;</TD></TR><TR><TD CLASS="quote">it's not the timming, plugs wires and the hole distributor is brand new, i hear a weird noise comming from the intake control selenoid i was thinkin a sensor possibly or the fuel pump or mayhbe the ecu. don' know is relly crazy what the car is doing.</TD></TR></TABLE>
So how did you check the timing? What is an intake control solenoid?
Old Nov 27, 2007 | 08:40 AM
mgags7's Avatar
Sounds to me like you replaced the distributor and put the plug wires on in the wrong order.
Either that or your MAP sensor is fucked/gone. That would cause the same thing.
redline870
Nov 23, 2008 05:51 PM
sammykat
May 30, 2007 01:48 PM
efadam
11
Jun 5, 2006 04:33 PM
WestEM1
Mar 28, 2005 08:30 AM
