92 Accord, are abs and non-abs cv axles interchangable
Hi all, I have a 92 accord that I am changing the cv axles on. I apparently bought abs axles but my car is not equipped with abs. Will they still work? Thanks,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord SiRT »</TD></TR><TR><TD CLASS="quote">yes the abs axles will work on the non abs model.</TD></TR></TABLE>
Say what?
They're different part numbers......
Unless the 90-93 is that much different than the 94-97
*edit*
Confirmed it from Majestic, they're different part numbers from the EX (w ABS) vs DX (no ABS)
EX Left Driveshaft 101263
DX Left Driveshaft 101262
It was my understanding that the teeth were not the same
Say what?
*edit*
Interesting, is it the other way around then?
Non ABS Axles will not fit on an ABS vehicle?
I know in another thread we had talked about it and whatever the OP was doing in that one they did not fit.
*edit*
on me then
*edit*
on me then
Even if the non-ABS axles fit the ABS transmission, which they probably do, you would lose the ABS function due to the lack of a sensor ring which would not be a good thing in my view.
