Wall near the fusebox...
Old Nov 23, 2007 | 06:54 AM
gotjnco's Avatar
Default Wall near the fusebox...
So yesterday, I tried wiring my folding mirrors, which was ALMOST a success, i installed the relay, I did the wiring okay, I tested the mirrors, etc.
I fished the wiring from the door jam to the ecu, behind the headunit, to behind my steering wheel, AND I TRIED GOING THROUGH THE FUSE BOX To the Door Jam... WITH NO SUCCESS!!!! aarrrgggg....
There is like a wall... after the fusebox....
So i tried putting my hand on my driver's side door jam, and took the rubber grommet out and stick my middle finger in, and tried LOOKING FOR MY FINGER over the fuse box... AND I DONT SEE MY FINGER and my finger is hitting a wall...
how can i fish my wiring so that it reaches to the door jam and FINISH my wiring to the next mirror...
My mirrors work, but I need the 4 wires to make my mirrors being able to fold...
Please help, it took me all day to do this... and i got sooo frustrated.
Old Feb 7, 2008 | 11:18 AM
gotjnco's Avatar
Default Re: Wall near the fusebox... (gotjnco)
bump
Old Feb 7, 2008 | 11:22 AM
Acidcrakker's Avatar
Use a clothes hanger and tape the wire onto the end and stick it trought the hole
Old Feb 7, 2008 | 09:16 PM
Hawkze_2.3's Avatar
The fuse box in the driver side kick panel? I would just unbolt it and pull it back a little so you can see what's back there. You will probably have to run it though the grommet with the door harness.
Old Apr 22, 2008 | 12:04 PM
gotjnco's Avatar
Default Re: Wall near the fusebox... (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">The fuse box in the driver side kick panel? I would just unbolt it and pull it back a little so you can see what's back there. You will probably have to run it though the grommet with the door harness.</TD></TR></TABLE>
Yea, i might have to take down the fuse box in the driver's side kick panel and try to fishline the 4 wires through the grommet... thanx for the info... yea... ive been lagging it... I still have 4 wires behind my head unit... i cant wait to wire this up already...
Old Apr 22, 2008 | 09:04 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotjnco &raquo;</TD></TR><TR><TD CLASS="quote">
Yea, i might have to take down the fuse box in the driver's side kick panel and try to fishline the 4 wires through the grommet... thanx for the info... yea... ive been lagging it... I still have 4 wires behind my head unit... i cant wait to wire this up already...</TD></TR></TABLE>
Oh, man I promise you it's extremely tight back there...wait till you unbolt that fuse box.
Old Oct 8, 2008 | 12:31 PM
gotjnco's Avatar
Oh, man I promise you it's extremely tight back there...wait till you unbolt that fuse box. </TD></TR></TABLE>
I still have not done this... time flies...
will do this sat...
06siracer
Honda Civic (2006 - 2015)
Aug 18, 2008 05:35 PM
djsire
Aug 30, 2007 10:15 AM
onepoint-gsr
Jun 12, 2007 08:58 AM
groo028
Jul 27, 2006 04:29 PM
