JDM B18C block... How to tell between ITR:SiR-G?
Old Nov 23, 2007 | 06:53 AM
GO-FIGHT-KILL's Avatar
Default JDM B18C block... How to tell between ITR:SiR-G?
I searched, but I kept getting the same "Measure the throttle body, what's the head coding? What does the intake manifold look like?etc" answers.
I'm buying JUST THE BLOCK, it doesn't have pistons, just rods and crank, girdle, caps, etc. I'm picking this thing up tomorrow, is there any way to tell which engine it is? I'm getting a good deal, so it honestly doesn't matter, but I'd just like to know.
Here's a picture of the block stamping:
He told me when he took the pistons out, they said P73-00, but he could have very easily have just told me what I wanted to hear.
Is there ANY way to tell from the engine stamping? From the research I did, it doesn't appear to be so easy.
Any input would be greatly appreciated.
Old Nov 23, 2007 | 07:01 AM
RTW DC2R's Avatar
i asked this same question a long time ago but dont think i ever got a clear answer.
Old Nov 23, 2007 | 07:36 AM
Dave_B's Avatar
Doesn't really matter if it's just the block. Same casting and all that jazz...
Old Nov 23, 2007 | 07:56 AM
tartje's Avatar
Default Re: (Dave_B)
no way to tell from the engine stamp, have to look at the crank or rods etc.
Old Nov 23, 2007 | 08:01 AM
-RedneckDave-'s Avatar
Working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't really matter if it's just the block. Same casting and all that jazz...</TD></TR></TABLE>
Old Nov 23, 2007 | 09:43 AM
Default Re: (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">no way to tell from the engine stamp, have to look at the crank or rods etc.</TD></TR></TABLE>
That's what I'm asking, the engine is apart, I can easily check the rods/crank. If they say "R", they're Type-R components, correct?
Like I said, I don't care, they're the same block, I would just like to know.
Old Nov 23, 2007 | 10:23 AM
tartje's Avatar
Default Re: (GO-FIGHT-KILL)
yea, look at the rods to see if they have R on them
Old Nov 23, 2007 | 12:30 PM
Same with crankshaft I imagine?
Old Nov 23, 2007 | 01:21 PM
tartje's Avatar
the crank has larger counter-weights on the R
edit*
here: https://honda-tech.com/zerothread?id=423970
Old Nov 23, 2007 | 02:31 PM
^ That helps, thanks Geeee-off.
Old Nov 23, 2007 | 02:43 PM
NIKE SB'd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">the crank has larger counter-weights on the R
edit*
here: https://honda-tech.com/zerothread?id=423970</TD></TR></TABLE>
Most easily noticable by eyeball, the ITR crank also has extra lubrication holes on the end counterweights.
Old Nov 23, 2007 | 03:42 PM
Well it doesn't matter anyway, the deal kept changing, a great deal turned into an "Ehhhhh" deal, and it just wasn't worth the effort for what the block was (Grinded up to fit a turbo, scored cylinder wall, no bearings, no oil pump, no water pump, etc).
I'll catch the next one.
Old Nov 23, 2007 | 06:56 PM
TeamJDM's Avatar
that engine serial number was re-stamped.. hence more then likely it is stolen..
Old Nov 24, 2007 | 12:13 AM
SuckMyDOHC's Avatar
oil cooler?
Old Nov 24, 2007 | 09:13 AM
Default Re: (TeamJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamJDM &raquo;</TD></TR><TR><TD CLASS="quote">that engine serial number was re-stamped.. hence more then likely it is stolen..</TD></TR></TABLE>
How can you tell?
Old Nov 24, 2007 | 09:16 AM
JjuuN R's Avatar
Actually he is right, definitely re-stamped... You can tell underneath the "new" stamp that it was sanded/smoothed down, and that B is way off from what it normally looks like, and I also want to point out the "font" on the stamp is a lot thinner then what Honda uses...
Old Nov 24, 2007 | 09:45 AM
For reference:
Old Nov 24, 2007 | 09:46 AM
It's not even the same font... Hmmmm... Maybe it's a good thing I strayed away.
Old Nov 24, 2007 | 10:05 AM
JjuuN R's Avatar
Definitely man.
Old Nov 24, 2007 | 04:42 PM
crxgator's Avatar
yeah, i was going to post it was probably stolen...looks like they cut part of the stamp off, like it should be a 1 or 5 next to the c, and part of the 8 is chopped off...
Old Dec 5, 2007 | 08:02 PM
SuckMyDOHC's Avatar
Default Re: (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i was going to post it was probably stolen...looks like they cut part of the stamp off, like it should be a 1 or 5 next to the c, and part of the 8 is chopped off...</TD></TR></TABLE>
Not on a JDM block.
Old Dec 5, 2007 | 08:08 PM
Parada's Avatar
Default Re: (SuckMyDOHC)
holy resurrection batman.
id have to agree with the fact that it looks a little shorter, how come theres only 6 numbers below the "B18C" and the rest, including my block has 7 numbers there? thats a serious question by the way.
*edit* sorry, its only a couple weeks old, i just realized there arent 24 months in the year lol
Old Dec 5, 2007 | 08:25 PM
The ****'s restamped definitely. It's in bad shape man, I'm glad I didn't pick it up.
Also, just look at the font... In particular, compare the 4s.
Old Dec 5, 2007 | 08:27 PM
Parada's Avatar
yup, good eye, completely different stamp. good call passin it up.
Old Dec 6, 2007 | 04:02 AM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">
Not on a JDM block.</TD></TR></TABLE>
im fully aware of that...this has nothing to do with why i posted my statement...
read the context next time...
