Electrical Problem? Car Shut Off
I was driving down the highway in my 99 Accord LX when all of a sudden like a scene from Transformers, the car shut itself off as if I pulled the key out. The key light was flashing to indicate removal as I was coasting and trying to make sense of what happened. The car did not lock up and I was able to stop and pull off to the side. It took 2 attempts to restart the car then it drove fine. I drove it this morning to work to see if there were any lasting effects and it seemed all good.
Has anyone ever experienced this problem? I only have an aftermarket headunit installed that will soon be taken out of the equation. The other thing is that when I initially start the car, I have to let it prime before turning the key completely, otherwise, it won't turn over.
Thanks in advance.........
i had the same problem today going to work. a good friend said it was the distributor or something inside it called the ignition coil or ignitor.
Honda Accord, Civic, CR-V, Odyssey & Prelude Vehicles
Date: 29/05/2002
Supplier Name: Honda Australia Pty Ltd
Product Make: Honda
Product Model: Accord, Civic, CR-V, Odyssey, Prelude.
Model Years From: 1997 through to 1999
Consequences: The engine may stall without warning.
Campaign Number: 5BO
VIN Range: [no data entered]
Serial Range: [no data entered]
Product Info: Honda Accord 97 98 99 Year model; Civic 98 Year Model; CR-V 98 and 99 Year Models; Odyssey 97, 98 & 99 Year Models; and Prelude 98 & 99 Year Models. Campaign 5B0 Ignition Switch.
Defect Details: Ignition switch malfunction may result in the engine stalling without warning. This condition may occur due to a high current surge passing through the ignition switch during the initial start up phase causing degradation of the ignition switch contacts.
Consumer action: Owners of affected vehicles will be contacted by mail. Contact your authorised Honda Dealer for further information.
Market Coverage: National
Recall Coverage: National
Date: 29/05/2002
Product Make: Honda
GRIFTERX
Jan 30, 2009 02:38 PM
