swap problem..
i've tried the search button but have not found the info i'm looking for... if anyone can help i'd be mucho happy-o. right..
anyways... will doors off a 90 rex fit on an 89 rex? and also will door panels from an 89 rex fit on doors from a 90? pleeeeeease and thank you.
your pal, downandgoing
88-91 doors are interchangable!
If 89 has same seat belt mounting(either pillar or door) panels are a direct fit
If not a little edge trimming will be required.
I have a 91 door mounted belts and converted to 91 SI pillar mounted panels cause i wanted a cleaner look with my racing harnesses. All i did was trim the edge near the door opening with a razor, Of course you should peel the vinyl back and then trim and pull vinyl back to cover your trimming!
EASY
EASY
661rex89si
Oct 2, 2006 02:43 PM
