Error code on D16Z2 engine and oil lickage in the distributor
Old Nov 22, 2007 | 11:59 PM
basitun's Avatar
Default Error code on D16Z2 engine and oil leackage in the distributor
Hello my friends,
I got a 4th gen Civic Sedan 4WD with D16Z2 engine (maybe close to D16A6)
So the question here is :
I got an oil leackage from the distributor so I think of replacing the o-ring but .
I am wondering what is the type of this TDC/Crank sensor (mechanical or with hall sensors), and wonder is it possible the error code 8 to come becouse of the oil in the distributor ... ?
P.S.
I was reading a lot of things about the D16A6 motor and the info for mine D16Z2 is rare. What I want to say here is that many people are saying that they are pretty the same but when I was changing the timing belt it was different from the D16A6 timing belt , just giving the info for the other D16Z2 owners ... the chasiis coed of the car is EE5 and it is EDM (after a correction from a friend here I understood that it is EDM) .
Modified by basitun at 3:18 AM 11/23/2007
Modified by basitun at 4:49 AM 11/29/2007
Old Nov 27, 2007 | 05:04 AM
~sp33~'s Avatar
EFB055
Is the D16z2 single cam? Is it carb'ed or fuel injected?
Old Nov 28, 2007 | 09:01 AM
basitun's Avatar
Default Re: (~sp33~)
It is MPFI - In some catalogs they show that the distributor for D16A6 is the same...
I changed the O ring so now the oil is not a problem...
After 2 or 3 days I will see the signal from the TDC with an oscilloscope so I will know is the problem in it...
pbcdb
Apr 21, 2004 09:42 AM
allm0torGSR
Mar 30, 2004 09:55 PM
sitrucjr
Feb 19, 2004 07:42 PM
Pele
Dec 29, 2002 11:29 PM
Eg6_JDM
Sep 26, 2002 09:26 AM
