Suspension & Brakes Theory, alignment, spring rates....
Car pulling
Old Nov 22, 2007 | 09:06 PM
ware's Avatar
Default Car pulling
im on si rims with bridgestone potenzas which have camber on the OUTSIDE i had them flipped so the camber would be on the outer side. About a month ago i hit a curb pretty bad and the left front tire took all the damage (hit the curb head on, turned the wheel slightly to the right so the front left took the most damage) i took it to get aligned right after but it still pulls to the left and i get sudden pulls when doing slight movements such as changing lanes. Do you guys think i could have bent or messed something up? . i checked but nothing visible shows. Thanks
Old Nov 23, 2007 | 12:09 AM
p10hlm's Avatar
Default Re: Car pulling (ware)
yes something is damaged, do you have the old numbers from when you did the alignment after you hit the curb
Old Nov 23, 2007 | 05:54 AM
crexer's Avatar
yes
Old Nov 23, 2007 | 03:39 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys think i could have bent or messed something up?</TD></TR></TABLE>
Definitely.
Do you have your alignment print-outs? Post the specs.
Old Nov 24, 2007 | 10:02 AM
ware's Avatar
Default Re: Car pulling (p10hlm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p10hlm &raquo;</TD></TR><TR><TD CLASS="quote">yes something is damaged, do you have the old numbers from when you did the alignment after you hit the curb</TD></TR></TABLE>
no.. i threw them away, but i will be getting it re-aligned on monday ( i have a lifetime alignment plan) and will post up the results. what could be damaged though?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Definitely.
Do you have your alignment print-outs? Post the specs.</TD></TR></TABLE>
will have some on monday however i did tell them to concentrate on the toe and get it as close to zero as possible. what could be damaged?
Old Nov 24, 2007 | 10:08 AM
Targa250R's Avatar
be professional
Lower control arm, subframe, knuckle, etc.
When you take the car in for an alignment, ask them to check out the left front suspension for bent control arms and damaged mounting points.
Old Nov 24, 2007 | 10:14 AM
ware's Avatar
Default Re: Car pulling (Targa250R)
i figured. ****, hopefully nothing major
Old Nov 25, 2007 | 03:19 AM
Mohsin's Avatar
the caster could be a degree off ont he wheel you hit causing bump steer and camber thrust. I'd say upper control arm / lca
Old Nov 26, 2007 | 05:37 PM
ware's Avatar
Default Re: (Mohsin)
ok got the alignment done, is this ok?
now, the guy said that i get the drift because with the impact of the hit, the subframe slightly moved. You guys think he's right?
Old Nov 26, 2007 | 05:54 PM
Bimmer99's Avatar
Default Re: (ware)
your beam has shifted/bent . the reason i think that is your ft camber and caster read outs are flip flopped. usually with a bent arm or knuckle one side would be out of whack and the other would be on par .i hope this helps
Old Nov 26, 2007 | 05:59 PM
ware's Avatar
Default Re: (Bimmer99)
damn.. will this effect the vehicle in any kind of way? he was telling me that in order to get it back straight.. wasn't going to be a walk in the park
Old Nov 26, 2007 | 08:26 PM
hayabusa160's Avatar
Default Re: (ware)
if you hit something on the left side it will explain why the left side is not the same as the right the camber and caster.
im going to take a guess and say your lca is bent because the caster is off
Old Nov 27, 2007 | 12:12 PM
ware's Avatar
Default Re: (hayabusa160)
so my subframe has moved?
Old Nov 27, 2007 | 10:09 PM
supracrx's Avatar
it could still be a few things. physically go look at the control arms to see if its bent. look at the subframe bolts and see if the subframe has shifted...u should be able to see some marks if it has moved or not, and look at the side that u hit. since the caster is off one degree. your car is lowered?
i think its the subframe that has moved...go under and look at the subframe.
Old Nov 28, 2007 | 09:20 AM
ware's Avatar
Default Re: (supracrx)
but if it has moved, will it be hard to re-align it in place?
Old Nov 28, 2007 | 11:11 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (ware)
Front subframe bolt holes are usually slotted or larger than needed, and the bolts have very thick, large washers to allow some adjustment. If it was shifted when the impact occurred, you should be able to see round marks on the subframe where the washers used to be before it shifted.
If you don't see any round marks around the washers, then it most likely did not move.
So if it was shifted, usually it's just a matter of loosening the subframe bolts and shifting it back into place. This would have to be done on an alignment rack, or a frame straightening machine.
Old Nov 28, 2007 | 12:21 PM
ware's Avatar
Default Re: (PatrickGSR94)
going to check it today
Old Dec 17, 2007 | 02:46 PM
ware's Avatar
Default Re: (ware)
ok so i checked the sub-frame and it seems fine .. any other theories/suggestions?
Old Dec 17, 2007 | 10:51 PM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
prolly ur lower control arm prolly ! i had this problem ! i changed a lower control arm it came closer ! my caster was pushed back ! after i went to DAREN AT WESTEND ALIGMENT and he worked his magic with the subframe and everythings back to normal !
Old Dec 18, 2007 | 08:06 AM
ware's Avatar
Default Re: (RED_90TEG)
pm'd .. btw is this the one in gardena?
Old Dec 18, 2007 | 11:58 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware &raquo;</TD></TR><TR><TD CLASS="quote">im on si rims with bridgestone potenzas which have camber on the OUTSIDE i had them flipped so the camber would be on the outer side. About a month ago i hit a curb pretty bad and the left front tire took all the damage (hit the curb head on, turned the wheel slightly to the right so the front left took the most damage) i took it to get aligned right after but it still pulls to the left and i get sudden pulls when doing slight movements such as changing lanes. Do you guys think i could have bent or messed something up? . i checked but nothing visible shows. Thanks</TD></TR></TABLE>
somethings bent, but your post alignment specs are kinda ok.
the cross camber and cross caster is not good. but liveable.
looking at your previous alignment, no wonder you got a lot of tire wear.
once again proves, ITS NOT THE CAMBER, ITS THE TOE THAT CAUSES UNEVEN TIRE WEAR.
Old Dec 18, 2007 | 12:06 PM
ware's Avatar
Default Re: Car pulling (Tyson)
i know that camber doenst wear out tires, this isnt about my tires being worn out. This is about the car steering/pulling/veering to the left. Hopefully by the end of the week i can get it checked out
Old Dec 18, 2007 | 01:51 PM
Tyson's Avatar
yeah i know, just using your post to make another point.
driving on already uneven tires will affect your tracking.
and yeah, the cross camber and cross caster affects your tracking as well.
so no real surprise to me.
Old Dec 18, 2007 | 02:01 PM
ware's Avatar
im pretty sure something is bent, its just a matter of pin pointing what it is.
Old Dec 18, 2007 | 02:08 PM
Tyson's Avatar
well again. of course something is bent.
and very typically the LCA and the subframe are the first to go.
so thats what you start to look at. whats the mystery?
