Questions????
1. I got a 1989 honda civic hatchback dx d15b2 SOHC just bought it a couple months ago.... when i rev it up greyish whiteish smoke comes out...????
2. there is oil in my plugs???
3. and once in a great while i have to go from 1st to reverse to get it in reverse is that a problem.????
BTW its has 225768 miles on it... i dont know if this has anything to do with those problems but the oxygen senser is bad i think...everythings stock.
please help!!!! honda lover in need
Modified by kryptproductions at 11:51 AM 11/23/2007
Modified by kryptproductions at 11:53 AM 11/23/2007
Your motor is burning oil, probley due to a few things. The oil on your plugs is from bad valve guid seals. pull the head and get a good valve job. But if those are bad the rings are most likely junk or will be soon. I say either rebuild the whole motor, or do a swap if you have the money. But bare minimum a valve job. As for your tranny, most trannys will do this. I always put mine in 4th first, then reverse. It has something to do with the guts in the tranny. You need to stop the syncros or it wont want to go in, or it will grind. I may be wrong about the exact reason it does this but it is normal. And your o2 sensor might be bad due to the motor passing so much oil and gunking it up. This might through a check engine light. My advice, fix the motor first, then replace the sensor. Putting a new sensor in first will just ruin a new sensor.
yeah im getting 2K coming in the next 2months and im either gonna get a d15 zc, or rebuild the complete engine that i got now and throw some performance **** in it.... and i was watching a video on rebuilding d15's and they said that u could bore a d15 out to a d16 and use the cam shaft arms and head form the d16 if i bored it out... is that true or a bunch of non sense???
thx for the awnsers to my problems tho much appreciated!!!
As far as I know you can use the d16 head, but boring the block isn't necessary to put a d16 head on. I think when you bore it, it's so you can use the higher compression pistons from the d16, but for all that work I'd just get the d16.
alright thx for the awnsers n **** my first honda besides the 87 carb. i had it blew first week i had it the thermastat was bad and i didnt know it, it drove fine when i test drove it and on the way back to my place didnt over heat or anything but the next day i started it and the rpm gauge flew up to like 4 grand and was rising slowly so i shut it off and checked made sure evrything was hooked up right checked the anti freeze again oil all that and started it again and it instantly got hot so i shut it off and got rid of it cuz i didnt want carbarated anyway...plus ef's own...
anyway i think i may get a d16a6, d16z6 or a d16y8 but im not sure tho ill stay posted
netplaceus
11
Sep 26, 2012 09:06 AM
piotrush
Jan 31, 2006 07:38 AM
piotrush
Dec 10, 2005 08:44 PM
