99 Civic wheels and speedo question
I just bought a well kept 99 Civic EX with 99k miles. It has the original 14" steel wheels and I would like to put the alloys that were available for it on. Two questions...... Where is a good place to look to purchase a set? .... If I upgrade to a 15" rim from a 14" one, what will I need to do to make the speedo accurate? Is there a new speedo gear available?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmh454 »</TD></TR><TR><TD CLASS="quote">Where is a good place to look to purchase a set? ....</TD></TR></TABLE>
The marketplace forums or eBay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmh454 »</TD></TR><TR><TD CLASS="quote">If I upgrade to a 15" rim from a 14" one, what will I need to do to make the speedo accurate?</TD></TR></TABLE>
Just get the proper size tires and the speedometer will still be accurate (assuming it's accurate now, with the stock size tires). 195/55-15 is the best matching size; the outer diameter is almost exactly the same as your stock 185/65-14 size (within 0.1 percent). You can also use 205/50-15, which is 1.6 percent smaller, not enough to worry about speedometer accuracy, since it only throws off the speedometer by 1 mph at normal highway speeds.
kay_animation
Mid-Atlantic (Sales)
Apr 16, 2008 07:33 PM
