help with my vtec head swap
Ok my friend gave me his vtec head and the others parts off his 95 ex and i have a 96 dx and i wanted to know what ill need to get to hook it up. I know his is 0bd1 and mine is obd2 but will that make any diffrence? And if any one has done this before and has some advice on how to do this.
well the reason most people do the ls/vtec or crvtec swap is b/c the blocks from the 2 non vtec motors have more displacement where as if you just doing from a 1.6 to a 1.5.... you might actually lose power.... b/c youll be decreasing displacement... well putting a vtec head on a lower displacement block instead of vice versa as with the ls/vtec or crvtec. but im no expert
but yes it can be done.......i have a basic how-to on it.....but don't know what extra you have to do pertaining to obd stuff.....here you go, hope it helps:
http://crx.honda-perf.org/articles/z...ap.html[br]
[Modified by 95hbMatt, 3:21 PM 6/25/2002]
u need a vtec ecu from an ex and than u need to add some wires for it. also u can run the vtec using a rpm activated switch and your stock ecu, this is the cheapast and simplest way to do it.
yeah but retard he is not putting it on a 1.5!!! the 96 and up are all 1.6l )d16y7)
so now you are the RETARD!!!
That is why people should watch what they say before they say it.
brian
brian
i did this same swap
i just finished putting a z6 head on my y7 block
i had to cut my old y7 distributor to fit the z6 head
other then that it pretty much bolts right in
the only other hard part is the intake manifold
here is a link on how to do that
http://www.makuragi.s5.com/civic_99/Y8maniswap/
yes i know its for a y8 intake manifold, but its the same thing for the z6 intake manifold
you will also have to wire up the vtec solenoid to either an obd2 or obd1 ecu
you could also wire it up to a rpm switch, but getting a new ecu is what i would do
good luck
[Modified by RoaringTurtle, 6:44 AM 6/26/2002]
good luck
SilverAWD
Oct 6, 2008 09:34 PM
T3hMetalGear
20
Jan 21, 2006 01:11 PM
civicracer1993
Jan 13, 2003 01:51 AM
LOWLIFEHATCH
Apr 16, 2002 05:23 AM
